Kubota BX Plowing Snow Video
   / Kubota BX Plowing Snow Video #1
94BULLITT
Super Member
USA
yes
Here is a little video of me plowing snow with the BX earlier this week.
   / Kubota BX Plowing Snow Video #2
How much snow did y'all get up that way?
   / Kubota BX Plowing Snow Video #4
do you always pull your blade with it turned backwards?
I always run the blade the opposite way it should be ran when I am plowing snow on gravel. If it is deep I will push backwards.
Running with cutting edge opposite the direction of travel is also a good way to level gravel.
   / Kubota BX Plowing Snow Video #6
I will have to try that... I have about 800ft of gravel steep driveway and my blade can cut too deep at times if I am not 'feathering' it.
Also when you are driving forward, the shorter your top link is the less cut it will have. Thanks for the comment on Youtube too:)
   / Kubota BX Plowing Snow Video #8
However, if you are using the blade at an angle, you can end up with one end or the other in the air when you make this adjustment.
   / Kubota BX Plowing Snow Video #9
That Kubota sounds like its wound up pretty good. What rpm do you run it at? Your definitely not standing still, your tractor is like mine you can really hear the hydro, I run mine at 1800 to 2000 rpm when plowing seems to work best but I wonder if might be a little high.
I run the BX at full throttle (3400 RPM) when I plow snow.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
