Mowing kubota bx brushhoging
/ kubota bx brushhoging #1
sdd1986
grove, ok
kubota bx25
Does anyone brushhog with a kubota bx. How big is it?
Here is a video om my bx 25 with a old cutter.
/ kubota bx brushhoging #3
I haven't in a couple of years as I have too much ground, but I have done so in the past using a 48" cutter. The ground clearance is not much and the steering rod boots are pretty exposed, so I tore mine up and subsequently added a protector from Bro Tek.
/ kubota bx brushhoging #4
I have a 48" Brush Bull that I run off my 2660. I've been doing blackberry eradication on the back slope. I'm going to go with the Bro-tek plate before spring. As it is, I back up the slope very slowly so the stalks are chopped up pretty well. No problem with the fan yet, but I'm on borrowed time. I engage the mower at low rpm as there is serious torque when that mower pulls in. The BX with my 60" mmm and the bucket removed is a great mower. It is a comfort having both;)
/ kubota bx brushhoging #5
I've got a bx2350, I use a King Kutter XB48 behind my tractor I wouldn't want to use anything larger. I use a Bxpanded skid plate with it.
/ kubota bx brushhoging #6
I use a Land Pride RCR1548 (48") behind my BX25. It is a real combination. Chops up stuff as big as 4" w/o a stutter, never stalled it or sheared a pin yet. I back in to a lot of stuff and let down onto it. Last year I cleared over an AC of brush, blackberries, dead trees, small alder trees. That is now usable grass land. Found a lot of junk previous owners had let the blackberries consume. Even had a barrel with 4 alders growing out of it.
Ron
/ kubota bx brushhoging #7
I run a Rankin 42" behind my BX24. Mostly used for mowing 5 acres of heavy, tall grass. I now run a full set of Brotek crunch plates (all 3) and a home-made protector for the front axle input shaft seal.
Tall grass wiped out my wiring harness and killed that seal. I may be the only one who's ever had that problem, but it wasn't fun.
Z.
/ kubota bx brushhoging #9
I use a Howse model 400 (48") on my BX25. I've never used one before so I can't compare it to others but I can say I am totally pleased with the results, and I'm amazed at what that thing can cut through. The pictures below show what it can handle.
Picture #1: The "before" picture of a steep bank about to be cut.
Picture #2: The "after".
Picture #3: The rough stuff. The foreground used to look like the tall stuff (over 6 feet) in the back. A couple hours after this was taken, the stuff in the back looked like the foreground.
Cherry Picker (A65640)
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
Truck Tool Box (A65640)
Truck Tool Box...
