Kubota BX 1860 Mid & Rear PTO Cover???
   / Kubota BX 1860 Mid & Rear PTO Cover??? #1
tpeachey
New York
Kubota BX 1860-FEL-54mmm
I am new to the site and just picked up a Kubota BX 1860 FEL & 54 MMM. I removed the deck because it won't be in service for the winter and don't have anything protecting the mid PTO from the snow and ice I am expecting soon. I looked on Kubota's website and they offer nothing and the dealer said he would look into it. I would appreciate any links or suggestions as I am worried that the PTO would wear too quick without anything covering it. Thanks.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #3
technically there is a protection plate for mid - check this website
Bro-Tek Skid Plates .
Or do what I did- build your own skid plate.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #4
Agree, another benefit of the Bro-Tek rear skid plate. Has a swinging "trap door" that you close when the MMM is off so the PTO stub is protected.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #5
Bought Bro Tek; don't put anything on the rear PTO.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #6
Kubota offers a little cup to protect YOU from the rear PTO.
The don't provide anything, by way of a cup for the mid, which I assume is your original question.
The mid PTO is somewhat vulnerable, but so is the HST filter and rear trans casing itself, I suppose, given the low ground clearance.
Your greater concern needs to the HST cooling fan.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #7
yeah I agree- another reason why you need a belly skid plate.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #8
A few years ago there was a thread where someone made a cover for the mid PTO out of a short piece of PVC pipe, a pipe cap, and a large pin clip like on a trailer hitch pin. It works very good.
   / Kubota BX 1860 Mid & Rear PTO Cover??? #9
I need something to cover the REAR PTO drive. I saw a guy recommending a condom. :eek:
I haven't carried those things for 40 years. What's a SECOND option?:) and where might I buy same? thanks
   / Kubota BX 1860 Mid & Rear PTO Cover??? #10
Why does the rear PTO need a cover?
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 WABASH DVCVHPC 53FT DRY VAN TRAILER (A53426)
2013 WABASH...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2005 Case 650K Series 2 LGP Crawler Tractor Dozer (A51691)
2005 Case 650K...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
Case 580M Series 2 Loader Backhoe (A53117)
Case 580M Series 2...
