Kubota Bush Hog, Breaking Shear Pin, never before
   / Kubota Bush Hog, Breaking Shear Pin, never before #1
MarineKubota
Penngrove, Ca
John Deere 4520
Hi All,
I have Kubota B342 Bush Hog/Field Mower I used behind my '49 Ford 8N successfully for the last 4 seasons.
I now have it hooked up to me 2011 John Deer 4520. I've had about 2 hours mowing on the Deere with this setup with no issues. The PTO on the Deere is rated for 540 RPM, while the Ford is rated at 549.
I hit a cinder block yesterday and broke the shear pin. This is the first shear pin I've broken, even after hitting multiple softball sized rocks over the last 4 years. Oddly, when I replaced the pin, I got only 7 feet of mowing when the replacement pin sheared again, but this time, I had not hit anything.
I'm ordering a pack of shear pins.. but would like to understand what should be looked at before I break more pins. Any ideas?
   / Kubota Bush Hog, Breaking Shear Pin, never before #2
it should have a slip clutch if its like the model shown on google. If it does you need to check and see if it is working it may just need a slight adjustment . using a sub par bolt to as a shear pin will not hold. I use grade 5 bolts on mine 6' mower.
   / Kubota Bush Hog, Breaking Shear Pin, never before #3
same here i use a grade # 5 full shoulder shear pin.
Are you saying that it could have a slip clutch AND use shear bolts? I understood generally it would be either/or. I can't find my mower in a google search
   / Kubota Bush Hog, Breaking Shear Pin, never before #5
The 8n with transmission driven pto os easy on stop starts. With electric clutch I engage / disengage pto at idle and then spool up to speed to reduce shock on the driveline. Also some bush hog shear bolts call for grade 8, grade 2 may be a bit soft but maybe check manual before making that switch. Even with a slip clutch the bolt will eventually fatigue and fail, about every 50 hours or so in my rocky terrain with an rc2072 and properly adjusted slip clutch.
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
