Kubota Bush Hog, Breaking Shear Pin, never before
   / Kubota Bush Hog, Breaking Shear Pin, never before #1
MarineKubota
Penngrove, Ca
John Deere 4520
Hi All,
I have Kubota B342 Bush Hog/Field Mower I used behind my '49 Ford 8N successfully for the last 4 seasons.
I now have it hooked up to me 2011 John Deer 4520. I've had about 2 hours mowing on the Deere with this setup with no issues. The PTO on the Deere is rated for 540 RPM, while the Ford is rated at 549.
I hit a cinder block yesterday and broke the shear pin. This is the first shear pin I've broken, even after hitting multiple softball sized rocks over the last 4 years. Oddly, when I replaced the pin, I got only 7 feet of mowing when the replacement pin sheared again, but this time, I had not hit anything.
I'm ordering a pack of shear pins.. but would like to understand what should be looked at before I break more pins. Any ideas?
   / Kubota Bush Hog, Breaking Shear Pin, never before #2
it should have a slip clutch if its like the model shown on google. If it does you need to check and see if it is working it may just need a slight adjustment . using a sub par bolt to as a shear pin will not hold. I use grade 5 bolts on mine 6' mower.
   / Kubota Bush Hog, Breaking Shear Pin, never before #3
same here i use a grade # 5 full shoulder shear pin.
Are you saying that it could have a slip clutch AND use shear bolts? I understood generally it would be either/or. I can't find my mower in a google search
   / Kubota Bush Hog, Breaking Shear Pin, never before #5
The 8n with transmission driven pto os easy on stop starts. With electric clutch I engage / disengage pto at idle and then spool up to speed to reduce shock on the driveline. Also some bush hog shear bolts call for grade 8, grade 2 may be a bit soft but maybe check manual before making that switch. Even with a slip clutch the bolt will eventually fatigue and fail, about every 50 hours or so in my rocky terrain with an rc2072 and properly adjusted slip clutch.
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
Tires (A50322)
Tires (A50322)
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
LOT LOCATIONS (A54313)
