KUBOTA BT 1000 BACKHOE
   / KUBOTA BT 1000 BACKHOE #1
mann smith
2005 kubota L39
I am in the market for a kubota BT 1000 backhoe for my 2005 L39 TRACTOR. I REALY DONT NEED THE ENTIRE BACKHOE. I need the outrigger's for the BT1000 that i have now BUT AM WILLING TO PURCHASE WHOLE UNIT IF I HAVE TOO. ANYONE WITH any information or where i might find BACKHOE OR JUST THE OUTRIGGERS I WOULD GREATLY APPRECIATE IT. CAN EMAIL ME AT mannsmith675@gmail.com
   / KUBOTA BT 1000 BACKHOE #2
what's wrong with your outriggers?
HAD TO REMOVE CYLINDERS FOR REPAIR. hAD TO CUT CYLINDERS AWAY FROM STABALIZERS WITH A METABO CUTTING DISC. NOW I HAVE 2 PIECES OF THE OLD PIN AND NOT HAVING ANY LUCK IN REMOVING REMAINING PIN MATERIAL FROM STABALIZERS. 1,25" DIAMETER AND 2.50 IN. LONG. TRIED DRILLING OUT NO LUCK. TRIED PRESSING OUT WITH A PORTA POWER NO LUCK. NOW I AM ATTEMPTING TO CUT OUT WITH A TORCH AND IF THAT DOESN'T GO WELL I WILL BE IN THE MARKET FOR NEW STABALIZERS.
   / KUBOTA BT 1000 BACKHOE #4
Seen BT1000s come up for sale occasionally. Not sure if any difference between L39 and L45 versions.
Took me >2.5 years to find a BT1200. Sold at auction in Canada to a farm equipment dealer near Detroit, shipped to me in Tennessee. Worried about buying without seeing but worked out OK. Even came with a thumb.
Currently a BT1200 on eBay. 3X $$$ of what I paid.
Several members have shared their expertise in heavy equipment repair given enough information.
Porta powers come in 5,10 and 25 ton versions. Many stuck pins require >50 ton press. Having the proper tooling to press and contain when released a significant challenge to prevent injury. Worthwhile finding a shop that does that type of work sometimes.
   / KUBOTA BT 1000 BACKHOE #6
it should be repairable even if you torch cut the old 1 out. any good equipment repair shop could make you new bushings and weld them in and make you a pin for it as well.
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
1264 (A50490)
1264 (A50490)
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
