Kubota block heaters
/ Kubota block heaters #1
Teikas Dad
Live Free or Die
Kubota B3200
I searched and I searched, honest I did....and I couldn't find the answer.
I have a B3200 that I'm thinking about putting either a block heater or inline radiator hose heater on. I know for the Kubota block heater you unscrew one of plugs on the side of the motor. Does the block heater screw into the opening or is it a press in style? If it's press in then I think I'll go with the inline radiator hose heater.
/ Kubota block heaters #2
If the plug that gets removed is a screw in type, the block heater that is inserted would be a threaded type. If the plug is a pop out then the heater replacing it is tapped in. I have had both type over the years and no issues with either....I have not been impressed with the performance and reliability of the 2 rad hose types that I have had....just my personal experience.
/ Kubota block heaters #3
Im pretty sure the plugs are threaded with pipe thread. plan on it taking several hundred ft - lbs to break it free mine required me 240 lbs jumping on the breaker bar. Seal it with and anerobic thread sealant. I tried tape and had a slight leak twice. Not fun draining the coolant 3 times.
If i remember the one on my tractor was probably 1 1/8" thread and took somewhere in the range of an 18-21mm allen socket. My neighbors old b2400 was also threaded
Thanks guys, next question. I looked on Ebay and there are several OEM plugs listed but there are some that have a longer heating element. The OEM part number plug heating element barely sticks out past the end of the brass fitting. In my mind the ones that stick out longer provide a larger heating surface and should work better. They're listed at 400 watts and the seller says they'll fit B and L series tractors. However, I'm concerned that the longer element might hit the inside of the block.
Here's the link to one of the longer ones: Kubota Tractor Block Heater Freeze Plug Heater New | eBay
Here's a link to the OEM part: Kubota Block Heater Part #70000-73274
What do you think?
/ Kubota block heaters #5
I'd just go for stock My 85 hp 3.8 L holds more 9.5 quart of antifreeze and also uses a 400 or 450 watt element. At -5 °F I Will heat the coolant up above 32°F (my glow plugs will not come on above freezing.) In 1 - 1.5 hours. The placement in the block is in theory supposed to create a thermal current that circulates the coolant through the engine. I could not tell you how thick the water jacket is on mine let alone your tractor.
/ Kubota block heaters #6
I'd go with stock, too. That's what I did on mine. That way you know it fits the space in the water jacket and also avoids the hassle of figuring out if that part has US pipe threads or Metric pipe threads. Those pipe threads are too close for comfort, but still not quite the same.
The OEM part is beautifully made, and costs less. Throwing a tarp over the hood will make it heat up faster.
luck, rScotty
OEM it is! Thanks for the guidance, this site is the best! What did we do before the internet...other than booger up most things we tried to fix?:D
/ Kubota block heaters #8
This reminds me I need to order a block heater for my 5240. Gonna go with the kubota unit.
/ Kubota block heaters #9
Good idea to go with OEM Kubota. My block heater worked really good compared with a simple radiator hose aftermarket heater. those weren't very good.
There is also another type I used that worked well but still not as good as OEM block heater. It was a lower radiator hose heater with a tank on it and a separate line that connected to the drain plug on the block. It caused the water to circulate and was much better than the simple hose kind. Still not as good as the block OEM but an honorable mention.
/ Kubota block heaters #10
I went with the OEM for my 2620 and the only thing I wish I did was use tape like they said to. I tried the blue paste and that leaked so I drained the rad again and taped it up like I should have the first time.....no leaks and works great.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 72" Bucket (A60463)
John Deere 72"...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
