Backhoe Kubota BH90 Backhoe Questions
/ Kubota BH90 Backhoe Questions #21
Got it. This happens from using the three point not from using the BH due to striking the subframe?
/ Kubota BH90 Backhoe Questions #22
The bh92 is supposed to be way easier to put on. Hook on the bottom links instead of all 4 being holes with pins you have to line up.
/ Kubota BH90 Backhoe Questions #23
You got it! Raising and lowering the 3pt once the subframe is installed, can cause the lower sway stabilizers to come in contact with the subframe if you do not get the proper width adjustment.
Bent mine once, then I figured it out. LOL
Dave
/ Kubota BH90 Backhoe Questions #24
Now I've found a BH92 on a newer mx5100hst and I think I may just trade my tractor and not have to worry with finding a subframe. The next question is this...I have all my three point implements fixed up with quick hitch adapters. Will there be any problems with using the quick hitch on the arms with the subframe? Next does anyone have a bh92 operators manual on pdf file?
1968 BUTLER TANK TRAILER (A60430)
1968 BUTLER TANK...
2019 CATERPILLAR 320GC EXCAVATOR (A60429)
2019 CATERPILLAR...
203201 (A60429)
203201 (A60429)
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
2023 Deere 325G (A60462)
2023 Deere 325G...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
