Kubota b9200 electrical
/ Kubota b9200 electrical #1
sebes
elida ohio
kubota b9200
So I've been bragging about my b9200 being bulletproof and karma got me. I have nothing electrical. When I turn the key on there's nothing, no lights, no fuel gauge NOTHING! Thinking it was the battery I put a new one in and still nothing. I then went to the key switch. I checked it with a meter 1 terminal had 12 volts with the key off but when I turned the key on no terminals had any power. So I took it out and checked it by continuity and it checked out ok. I'm baffled! Any help out there would be greatly appreciated!
/ Kubota b9200 electrical #2
Sure it's not just a safety switch issue? In neutral, pto off, etc.....,
/ Kubota b9200 electrical #3
Have you checked all of the fuses with a test light or meter? How about any fusible links from the battery to the starter?
/ Kubota b9200 electrical #4
Begin at the beginning. Make sure the battery is fully charged. Clean the terminals and the cable ends. Replace cable ends and tighten securely. Follow ground wire to frame. Clean and tighten there. Now try your switch again. If still no joy check battery voltage while turning switch.
/ Kubota b9200 electrical #5
Seems like there is a fusible link around the radiator area going to the starter.
Edit: Sorry, that location is on my Mahindra. The Kubota B9200 schematic does, however, shows a fusible link between the starter and the center terminal of the "ignition" switch.
/ Kubota b9200 electrical #6
These schematics may be of some help in tracing your issue:
