Kubota B7800 hydrolics sound like it's cavatating.
   / Kubota B7800 hydrolics sound like it's cavatating. #1
UpholsterRuss
Kubota B7800
I have no power steering, weak and Shakey loader, and 3 point. Also low power in low won't even go on high. Is it my pump or could it be something else?
   / Kubota B7800 hydrolics sound like it's cavatating. #2
I would perform the simple things first before condemning a pump.
1) have you verified system is full of oil?
2) when was light time filters were changed?
3) Has suction screen been cleaned? I believe that tractor has one but not not positive.
4) If rubber hose on pump inlet check for cracks in the hose. Also check if any clamps are lose.
Items 1 - 3 are mostly suspects.
Other possibility depending on location and temps is water is system has frozen blocking suction screen.
   / Kubota B7800 hydrolics sound like it's cavatating. #3
May I add drop the 3pt down a little if all the wat up.
   / Kubota B7800 hydrolics sound like it's cavatating. #4
Check for air in the system.
   / Kubota B7800 hydrolics sound like it's cavatating. #5
If it comes down to the hyd pump, I have one I'll sell you.
   / Kubota B7800 hydrolics sound like it's cavatating. #6
Be careful or you will be detected by enemy destroyers. -thanks Tom Clancy
   / Kubota B7800 hydrolics sound like it's cavatating. #8
What do you mean by that?
I mean I read a lot of Tom Clancy novels and when your submarine is cavitating, it makes noise that can be detected by enemy destroyers.
UNUSED FUTURE 25' 4 GUAGE JUMPER CABLES (A58376)
UNUSED FUTURE 25'...
Sterling AT (A56436)
Kuhn HR3030 (A57148)
EPIROC SBU220 EXCAVATOR HYD HAMMER (A52709)
EPIROC SBU220...
DIRT DOG APP48.3 (3) SHANK 48" SPRING TOOTH HARROW (A58375)
DIRT DOG APP48.3...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
