Kubota B7800 Engine Dies Randomly
   / Kubota B7800 Engine Dies Randomly #1
Truklaw
Loomis, CA
kubota B7800
I have a 3 yo Kubota B7800 that, until recently, has been running beautifully. Over the past day or so it has developed a tendency to die unexpectedly. It is not overheating and there seems to be a correlation to the amount of stress put on the engine (either driving up a hill or engaging the belly mower) and its tendency to cut out. All fluids are topped off and it has fresh diesel in it. Thoughts?
   / Kubota B7800 Engine Dies Randomly #2
Try changing fuel filter and cleaning air filter. Make sure the fuel is good and not gelled or has water/trash in it.
In CA, I'm sure it's not gelled, sorry.
   / Kubota B7800 Engine Dies Randomly #3
yea that was my thought too, Fuel or air starvation when you ask for more power
   / Kubota B7800 Engine Dies Randomly #4
Sounds like fuel problem if it was starving for air it would blow black smoke. Water or dirty fuel filter would be my guess.
   / Kubota B7800 Engine Dies Randomly #5
Sorry for your problems. Could also be electrical, check connection at shutoff soloniod and plug in on injection pump. Does it always crank? if not might be a loose or bad battery connection which would cause fuel shutoff soloniod to kick out, shutting off fuel. Food for thought.
   / Kubota B7800 Engine Dies Randomly #6
What about the kill switch under the seat that shuts it off with no operator? Could be bad?
   / Kubota B7800 Engine Dies Randomly #8
My 7510 did the same thing. It was the shut off switch under the seat. Stopped for no reason. Sometimes it would start, sometimes not. Now the engine runs when I get off the tractor when the pto is going though.
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2017 JCB 3TS-8T TELE SKID STEER (A51242)
2017 JCB 3TS-8T...
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
