Kubota B7610 versus B7800
   / Kubota B7610 versus B7800 #1
DHBecker
I am trying to decide between the B7610 or the B7800. I have owned a B1750 for 14 years and am trading it in. The B7610 basically is the replacement for the B1750 with 24 hp vs. my old 20 hp. I like the greater power of the B7800, but am concerned that it will not maneuver in tight quarters as well as the B7610, which is 10" shorter than my B1750. The B7800 is about the same length, but 4" wider. The loader capacity on the 7800 does not appear to be greater than 150 lb more than the 7610, but the tractor is 400# heavier with 30hp, which might be an advantage. Turning radius appears to be about the same as my old tractor, for both of them. Any opinions on what would be the best choice? I maintain about 14 acres, with 6 acres woods, 3 acres pasture, 2 horses, 800 ft. winter driveway plowing, trail cutting with rotary cutter, grade & plow with a 60" rear blade, spray with a 50 gal. sprayer. The only negative comments I have found on the 7800 is that it has weak headlights. Greater cost of course, but I am hesitant to stay at the same size as my old one and tempted by bigger and more powerful. This may be the wrong reason to be influenced by however. I would appreciate any insights and personal exerience with these tractors. Thanks. /forums/images/graemlins/confused.gif
   / Kubota B7610 versus B7800 #2
The only thing I would recommend to you is that you buy the one you like best. But if it were me, I'd definitely go with the B7800, unless the price difference forced me to change my mind. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
   / Kubota B7610 versus B7800 #3
I've got the 7800 , never noticed and turning issues. Other than if i turn sharply it tears up the grass. Nice machine. Which one costs more? What will you be doing in the woods?
I cut the trails in the woods with the rotary cutter, clear brush, haul firewood, pull leaning dead trees down with a chain,etc. I can understand the tearing up the grass - I have ag tires on my old tractor. Thanks for your input.
   / Kubota B7610 versus B7800 #5
I have a B2410, the deluxe version of the B7610. I don't think its any more manuverable than the B7800. I wanted to keep weight down, but there are times I regret not moving up to the 7800/2910. If I remember correctly on the 7800 loader you can get a quick attach type connection to swap buckets/forks. I wish I'd done that.
(I know I can add a system from ATI, but its $1000 with forks)
I guess this is a 7610 owner saying buy the 7800.
   / Kubota B7610 versus B7800 #6
I have had a B7500 for three years and wish I had a B2910 or B3030. After 14yrs you need to treat yourself to more power. I know I will when I can financially do it.
   / Kubota B7610 versus B7800 #7
I bought a 7800 over the 2910 two years ago and have been more than satisfied. I've moved well over 300 yards of fill dirt with the FEL, leveled abou 1.5 acres, built several rock retaining walls and cleared a lot of snow with it.
Haven't wished for a larger or better machine yet.
   / Kubota B7610 versus B7800 #8
i just got my b7800 a few weeks ago - the machine is impressive. i am presently using it for mostly dirt work - grading, digging out tree stumps (with bh) and now building a practice motocross track. i have the wheels loaded and think that helps greatly with stability and putting the power to the fel. only drawback is that it will compress the ground where run over numerous times.
   / Kubota B7610 versus B7800 #9
The headlights can easily be fixed. For $2.99 a piece I went and got Blazer 50watt incandesent bulbs for the front of my tractor. They don't melt the lens on the tractor and put off all kinds of light.
Found that out right here on TBN. Never even knew they existed.
   / Kubota B7610 versus B7800 #10
tnmx,
Did you ever try the tiller for making the your mx track? How did it work? Tell me what attachments and techniques you're using and what works best.
Thanks!
1999-2010 Ford Pickup Truck Bed (A49461)
1999-2010 Ford...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
KLEEMAN MS192 MOBILE SCREEN (A51242)
KLEEMAN MS192...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
