Kubota B7510
/ Kubota B7510 #1
chrisshears
Canada
Kubota B7510
Hello All,
I'm a proud new owner of a Kubota B7510. I purchased this tractor second hand. It's the first Tractor, first diesel, first hydraulic piece of equipment i have ever owned. So i will have lots of questions over the next year or so.
For quick introduction. I am no mechanically inclined and depend of friends and youtube for everything down to changing a fuse.
My tractor is a 2006 (i was told?)
It has a loader, after market snowblower (which i did not get to work well this year),and an homemade plow.
It as 454 hours on it.
I had a lot of trouble this winter starting it. I think the battery is gone. Now the weather warmed up she starts everytime.
My first question(s) is I would like to get a service or operators manual.
I plan on servicing it this weekend. (changing fluids, filters, greasing.) I dont know anything about this, where nipples are, where flters are, drain plugs. I will need to purchase new fluids. I was planning on buying them at the dealer.
Second question, i want to buy a backhoe, what is a good aftermarket backhoe that will fit my tractor.
Thanks in advance or any response
/ Kubota B7510 #3
Welcome aboard!!
Nice tractor.
For manuals I went to Messicks a valued advertiser here. I'm not sure about them shipping to Canada but when I bought I got the manuals in two days.
BUT - they have all the Parts manuals digital!!
Kubota Parts | Full Service online retailer
go there and they email you the parts diagrams, usually within 30 minutes (but that may just be my mail provider).
Think twice about a backhoe. I went that route for my B7610. I got the Woods BH70-X and my B7610 meets it's MINIMUM needs. All told with delivery, tax, frame, bucket etc. it cost more than my B7610. However for a few dollars more I plan on moving it over to my new-to-me M4700.
If you can buy or rent a mini-x you may be far ahead. It depends on your plan usage.
Again welcome aboard.
/ Kubota B7510 #5
Welcome to TBN:welcome:
/ Kubota B7510 #6
As the proud owner of a B7510 (2005) gear tractor with FEL welcome. My unit has in excess of 2000 hrs with never a problem except clutch pedal return springs (about three per year). When you say it it is a problem to start in the winter do you mean it won't crank (probably needs a new battery; I have replaced mine) or do you mean it cranks but won't start ( do you turn your key to "half crank" to activate the glow plugs?) My unit up here in the wilds of Ontario, Canada will start fine down to 25 below with out a block heater if I use the glow plugs, not at all if I don't and will start at -40 with a block heater. I use Kleenflo fuel conditioner in the winter time. I had a smyth 54" snowblower and none a 60" Agro trend blower and both worked fine (the smyth a little better than the Agro trend,,,, don't know if it was because it was smaller but definitely more robust.
Larry
/ Kubota B7510
i got a manual for my tractor thanks.
I was thinking about getting a backhoe and wood chipper.
I REALLY want a backhoe, but thanks for heads up will have to do some research.
/ Kubota B7510
Starting issue. I do turn the key half way, count to ten to warm up glow plugs and then it just clicks.
i had a friend of mine com up, we took of the magnito (spelling!) cleaned it up. Did a few checks on the charge going into the battery adn when idling the tractor wasn't producing enough charge to keep the battery where it needed to be. But when working at higher rpm's it slightly increased enough. When i hook up the booster cables to it she starts right away, if i charge the battery it only takes 20mins and she's good. Last night i drove it over to my neighbors for a visit, when i got ready to leave she did the clicking thing and wouldn't start. hoping it's the battery, will buy a new one i guess. It was cold last night and when driving over to my neighbours i was in 3rd gear with lights on, so i'm thinking that drive may of drained my battery.
/ Kubota B7510 #11
/ Kubota B7510 #13
Hi i got a B7510 kubota i bought it new ( 2007 ) two days after tractor stop ... battery dead so i got a cab with light on it so i called the dealer they told me magneto not strong enought to run all the lights .I bought the kit from kubota alternator belt etc... 200$ . magnito is only 14 amps alternator is 39 amps since that time no more problem .
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
(1) UNUSED 12.4-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12.4-24...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
(8) John Deere Tractor Weights (A64119)
(8) John Deere...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
LP Tank (A64119)
LP Tank (A64119)
