Kubota B7510 HST transmission oil volume
   / Kubota B7510 HST transmission oil volume #1
treeguy99
kubota B7510
so I've just joined this website in an effort to get the right info so I can properly change the transmission oil in my B7510. I've done a ton of reading online. My manual and website info says that the capacity is 15.3 litres. After carefully following instructions on Messicks (best i could find) I can only drain 10.7 litres from it. What am I missing? I removed a plug from the front transmission case, a plug from near the mid PTO and a plug off of each side of the rear axle. I removed both filters and the screen. Don't want to refill it with having left old oil in it.
Scratching my head in Thunder Bay
   / Kubota B7510 HST transmission oil volume #2
Good luck in draining out every hose & cylinder as that's a near impossible task. Just drain all you can out of the transmission housing (sounds like you already have) then refill. A little leftover wont hurt unless it's really contaminated. If it's that contaminated you need to refill, run it a bit, the drain & refill it again. Unless it looks like a milkshake or had something blow up inside it's not going to be that contaminated.
thanks so much for the quick response. I will finish off the job and keep close attention to replacing the same amount as I took out.
for those coming behind me...the screen 26mm nut and filters were tightened at the factory by a gorilla. I had to use extensions on the wrench. Don't use anything but a 26mm socket on the screen nut head. Messicks website was useful as was this.
2022 Harley-Davidson FXLRS Motorcycle, VIN # 1HD1YWZ11NB021297 (A51572)
2022...
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
