Kubota B7500 HST loses power and blows white smoke
   / Kubota B7500 HST loses power and blows white smoke #1
DavidB2445
Weyers Cave, Va
Kubota B7500 HST
B7500 runs well for a hour brush hogging, The. Loses 500-1000 rpms and blows white stinking smoke. I have changed fuel filter and added a bottle of Sea Foam but I don't see any difference.
   / Kubota B7500 HST loses power and blows white smoke #2
G'day check your valve clearances sounds to me like they may be a bit tight
Jon
   / Kubota B7500 HST loses power and blows white smoke #3
hows your coolant level?
Are you loosing coolant?
White smoke iusually raw, unburnt fuel in the exhaust stream caused by
■ bad fuel injection timing
■ bad fuel injectors
■ Low cylinder compression (leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze).
White smoke on start up and then disappears as the engine warms up likely fouling deposits around piston rings and/or cylinder glazing.
Continuous white smoke indicates a mechanical defect, or incorrect fuel timing.
Water entering combustion will also create white smoke. (Faulty head gaskets / cracked cylinder heads or blocks)
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
