Kubota B7500 HST loses power and blows white smoke
   / Kubota B7500 HST loses power and blows white smoke #1
DavidB2445
Weyers Cave, Va
Kubota B7500 HST
B7500 runs well for a hour brush hogging, The. Loses 500-1000 rpms and blows white stinking smoke. I have changed fuel filter and added a bottle of Sea Foam but I don't see any difference.
   / Kubota B7500 HST loses power and blows white smoke #2
G'day check your valve clearances sounds to me like they may be a bit tight
Jon
   / Kubota B7500 HST loses power and blows white smoke #3
hows your coolant level?
Are you loosing coolant?
White smoke iusually raw, unburnt fuel in the exhaust stream caused by
■ bad fuel injection timing
■ bad fuel injectors
■ Low cylinder compression (leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze).
White smoke on start up and then disappears as the engine warms up likely fouling deposits around piston rings and/or cylinder glazing.
Continuous white smoke indicates a mechanical defect, or incorrect fuel timing.
Water entering combustion will also create white smoke. (Faulty head gaskets / cracked cylinder heads or blocks)
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
