kubota b7100d
/ kubota b7100d #1
mickuk
derby uk
kubota b7100d
Hi, want to mount hyd supply to rear of tractor, running from diverter valve, any ideas?? mickuk
/ kubota b7100d #2
So you want to flip the diverter switch so as to use the curl function of the loader valve for hyd operation at the rear of the tractor. .
That is not much different in using the remote for a grapple. Just some long hoses.
You could add a 3rd function valve to the rear for about $200, or a two spool valve remote valve.
/ kubota b7100d #3
:welcome:
To TBN Mick from Alabama, USA. How is the weather over there? Been a little cold here for this time of year here. Got 12.7" of snow last Wednesday and a half inch of ice this past Thursday.
/ kubota b7100d
Hi there, weather not too bad, mild and rainy! saw on the news about your snowstorms over there, if we had that much snow the country would be shut for the winter, see ya mick
/ kubota b7100d #5
I assume you mean the factory diverter valve under the front of the seat on the earliest B7100's. You'll need a fitting to replace the plug and a way to return oil to the sump. The problem with using this is that that oil comes from the top of the 3-pt piston and the the only way it gets flow is with the 3-pt raised all the way up and the handle held in the lift position. Depending on what you are trying to do, this may or may not be a problem.
Brian
/ kubota b7100d
Hi Brian,thanks for info, can go ahead and plan for modification as tractor is in slovenia on vineyard, trying to get all parts sorted when i go there in april, take care, mike
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2000 STERLING LT8500 SERIES WATER TRUCK (INOPERABLE) (A67714)
2000 STERLING...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2016 Ford Expedition SUV (A66738)
2016 Ford...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A67737)
2024 DODGE RAM...
