Kubota B7100
/ Kubota B7100 #1
Vkrzywosz
Kubota B7100
Recently purchased a used kubota b7100 and need hydraulic lines for back hoe any information appreciated
/ Kubota B7100 #4
You can tap off the hydraulics under the seat. There's a valve you turn for external implements. You'll probably need to T the return line. Some backhoe's seem to be setup to use the PTO to run an external pump. Do some searching on here and you'll find some pictures. The B6100 is the smaller HP version of the B7100. Do you have a loader? What year is the machine, the newer ones are a bit different.
/ Kubota B7100 #5
Ah - ha! So that's what that valve is for. Looked all through the owner's manual and not a hint that I could find. Thanks for the info. Very nice power steering thread, too - nice work.
1999 New Holland 688 Round Baler (A63688)
1999 New Holland...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
72" JCT TILLER (A62613)
72" JCT TILLER...
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
