Kubota B7100 Overhauled now will not run
   / Kubota B7100 Overhauled now will not run
I wonder if you have head issues, getting hot and compression is getting into the water passages causing the poor water circulation and lack of power. When it is running you seeing bubbles in the radiator? Or with radiator pressure tester installed is the pressure rising?
I don't think there is a head issue. There are no bubbles, no water in oil, etc. I put on a new head, as the former was cracked. Apparently, the last owner did overheat the engine.
The radiator appears to be OK,it although maybe some passage are partially blocked??? I have just flushed it out with a garden hose and water runs through it freely; not certain if that means water is getting through all passages. And, I did clean out all trash from the fins.
looks like Hooked_on _HP (Bill) was on to something with the piston ring gap. Tore the engine down yesterday and sure enough the oil rings were too tight. One of them would hardly go in the cylinder; cannot believe I totally forgot to check this. Anyway, I of course broke the last oil ring putting it back on the piston so it will be next weekend before I find out for sure but it definitely looks to have been the problem.
The pistons had a slight outline of the exhaust valves, so I am glad I took it back down. The overhaul kit came with an thin extra head gasket and I plan to add it on reassembly. Hopefully that and a new oil ring will put an end to this saga.
Thanks for all the help and will update once it is back together. If someone thinks the addition of the "extra" head gasket is the wrong way to go then, the please speak up.
   / Kubota B7100 Overhauled now will not run #33
I don't think a double head gasket is the way to go.
   / Kubota B7100 Overhauled now will not run #35
Sounds like Bill made a good call:thumbsup::thumbsup:
No on the double gasket.
   / Kubota B7100 Overhauled now will not run #36
The valves should be NOWHERE near the pistons . Either the head gasket is too thin , the valve timing is wrong or the rockers are set too tight .
These things DON'T have a water pump , WTH ?
I know the timing is set correctly in regards to the gear set as shown by Eagleview. The repair manual discusses using a plastigage to check spacing between piston and valves with min. allowance of 0.6mm and says the gap may be increased by using a shim gasket. I don't particularly like the idea of stacking head gaskets but the overhaul kit did include a regular head gasket, which I used, and then a second thinner metal?? head gasket. The thinner gasket is I assume the shim gasket referred to in the manual. I thought I would also increase the valve gap to max end of the range to possibly provide a little more clearance.
What other recommendations do you guys have??? If you go back to the very first page you will see a picture of the alignment of the timing gears with the dots not lined up as shown in the manual. This is what I found when I took it down, the dots were not perfectly aligned as shown in the manual. When going back, I lined up the dots as shown in the manual.
   / Kubota B7100 Overhauled now will not run #38
Where was your piston at when you took the pictures on the 1st page?
I cannot recall now, as I took the pictures back in December. I checked back through the pictures I have left and none show the position of the pistons. I do recall spinning it around and around that was the closest they ever came to lining up with each other.
If I were to pull the timing gear cover off to recheck, where should the piston (assume we are talking about front piston #1) be when these timing marks are aligned?
   / Kubota B7100 Overhauled now will not run #40
Check the two fuel return lines to the tank . If either are chaffed or cracked , they will suck air as they loose their prime (for the want of a better term) and aerated fuel would return to the filter housing . This would stall the engine out .
I would also back the rockers off a little to give you some more lash as there is something going on with piston to valve clearance .
I would also buy an electric inline water pump when you do get it going , I dont like that Thermo system one bit . I would bet it is the cause of all the cracked heads people speak of . Thermo siphon does work , but what happens when you are in a bit of steep country and you get an air lock in the head ? You get a hot dry spot with no circulation to force it out and a cracked head would be a surety .
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
