Kubota B7100 Overhauled now will not run
   / Kubota B7100 Overhauled now will not run #91
"Anyone know where to get a good aftermarket replacement for the oil cooler? A new kubota oil cooler is over $400. It is pretty small cooler and I can see no reason it should cost anywhere near what they want for a new "factory" cooler. "
Any good radiator shop can rebuild you unit, replacing what needs to be replaced - check around.
The radiator could well be operating normally. My Isuzu diesel generator radiator will run at 170 deg at top of radiator and bottom tank will be room temperature. That's what they're supposed to do, cool the water. Does the cylinder head get too hot? Couldn't find it in your posts.
Yes,the cylinder head does get hot. I have a fitting ordered so I can installed a temp gauge in the top radiator hose to see just hot it is actually running.
If the coolant is not boiling/making a rumbling sound when it finally dies, I don't see why it would be seizing up because it is too hot. There is a lot of friction as new piston rings first wear against a freshly honed cylinder- and yes things will get tighter as the engine warms up.
Does this injection pump have a governor that functions at idle? I know diesel injection pump governors work well at maintaining engine speeds regardless of load, but I am not knowledgeable enough to know how effective they are at idle. I believe that maybe the engine is just being bogged down by all the friction (and slightly rising temps/increased friction) and the current amount of fuel injected to keep the engine at a slow idle isn't enough to keep it running. If it was mine, I would run the engine at 25% throttle the next time I started it and see exactly what happens when it dies (does it bog down slowly or quickly die just as you pulled the engine kill knob).
Leave the rad cap off and kill it at the first sign of steam if you are afraid to get it hot (the pressure behind the cap raises the boiling point).
Maybe even crack an injector line and make sure it is still leaking as the engine dies (to make sure the injection pump isn't losing prime or malfunctioning).
I do not hear any rumbling or signs that it is trying to boiling over. I am a little gun shy on too many attempts to keep it running if it seems to want to seize up. My neighbor has the same tractor but is out of town. I am waiting for him to return in a week or two so I can observe his running to see how hot it gets and how the temp dissipates across the radiator (hot only at top or across the entire face).
There is a governor but it is all internal and I cannot see how it is working.
I will make another run at is just as soon as I can see how things should perform based on my neighbor's tractor.
Thanks for the suggestions.
Any updates?
UPDATE
Last time I had put it all back together and built a small engine stand to attempt starting it while separated from any possible "downstream" source of resistance based on the recommendation of the guy at the machine shop. They had rechecked all clearances after I had torn it back down after the initial attempt to run it after the overhaul. Initially it would run maybe 20 seconds to 30 seconds before appearing to get hot and stop running. After putting it all back together and in the process getting the timing gears aligned correctly (think I had crank shaft off one cog when I put it together the first time) it ran for what seemed liked a few minutes (did not time) before it appeared to get hot and die. Thinking I had it right this time, I put the engine back on the tractor and checked the injection timing. The injection pump was set up like it came to me, but appeared to be off 5 degrees. I adjusted the shims until it appears to be right on based on the very first indication of injection at 25 degrees BTDC on the front cylinder. I had also noticed it was missing the fan shroud, so I bought one of those and installed it along with a temp gauge in the upper radiator hose this morning.
My neighbor has the same tractor, so I had him run his at idle for 3 minutes so I could see how hot his appeared to be getting and how the heat was moving across the radiator. After running for three minutes, the head was pretty hot but I could put a finger on it briefly without too much discomfort. The radiator was hot at the top only, similar to what I have observed on mine.
This morning, I was finally ready to try it again. Bleed the fuel lines, filled the radiator and fired it up. It idled very smoothly, with no smoke. There was just a little smoke when I would accelerate, which is normal per the manual. It ran fine for two minutes and began to show a hint of smoke and then died. I was showing about 45 psi oil pressure the entire time and the temp gauge only got to ~120 degrees. I had left the radiator cap off and no bubbles or any other unusual observations. The head was hot, such that I could not hold a finger on it. Not scientific, but did seem to be hotter than my neighbors tractor after his ran for three minutes. I looked everything over, started it up and it ran for about one and a half minutes and then appeared to bog down and die.
I am really at a loss, as it seems to be running perfectly but then appears to get hot and try to seize up. It never has boiled over and the temp gauge never got above 140 degrees, although head seemed hotter than that to the touch. I am wondering if it could be running too lean and getting hot??? I have not checked the injection pump but the tractor has about 2600 hours, so I guess it could be worn and causing a lean condition. Anyone have any experience with this??
   / Kubota B7100 Overhauled now will not run #96
I had a perkins that did the exact same thing as you are talking about. Rebuilt the pump, and it was fine. All diesels runs fuel lean. But if you have smoke sometimes, that's a good sign. Have you checked pressure of the lift pump? Are there any fuel sieve screens in front of the lift pump? It could be lazy and not supplying fuel to IP. It sounds like you have the engine worked out, and it's a fuel issue now. I would rip that injection pump off and have it run on a flow bench just for peace of mind. Also, it's a new engine, it's going to run hotter as everything is so tight right now.
Thanks, I cannot think of anything else to try. I am obviously not a diesel mechanic, so I am not familiar with the effect of problems that may come from a bad injection pump.
   / Kubota B7100 Overhauled now will not run #98
Here's something that you could do to test whether it was really seizing up. Turn the crank pulley bolt with a torque wrench with the engine cold and record the max amount of torque needed for 2 revolutions. Start the engine and run it until it dies and repeat the test right after the engine dies to verify that the engine is not seizing up.
If it shows no signs of seizing up, I'd run it some more and try to crack an injector line to see if it still gets fuel as it dies.
   / Kubota B7100 Overhauled now will not run #99
Are you saying that you done a complete rebuild without having the pump and injectors serviced?????????
I installed new injectors purchased at Kubota. I have not done anything with the pump, but it does not give any sign of starving for fuel.
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
Auger Skid Steer Attachment (A50322)
Auger Skid Steer...
2018 Ram 1500 Crew Cab 4x4 Pickup Truck (A51568)
2018 Ram 1500 Crew...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
