Kubota B3200 Shut off while idling/ won't start back up
   / Kubota B3200 Shut off while idling/ won't start back up #1
SammyLove
Kubota B3200
My tractor was idling, I got off of it and was hooking my boat up to it to move it, it shut off and will not start back up, I checked the neutral switch, the seat switch seems to be working, any ideas?
   / Kubota B3200 Shut off while idling/ won't start back up #2
If it has an electric shut off, make sure it’s getting power.
any advice on how i can find that out, I only know of the key, its always started right up without sitting on the seat, i checked the neutral switch, verified the fuses are good
   / Kubota B3200 Shut off while idling/ won't start back up #4
Welcome aboard, and hope it's something simple. Probably a misbehaving switch. I had to adjust a neutral switch on an L3200 because of intermittent starting problems. Sometimes I had to gently work it back and forth to get to the sweet spot.
Then there are odd things like bumping the PTO switch "ON",
   / Kubota B3200 Shut off while idling/ won't start back up #5
Read the material I will provide below very carefully. The OPC did exactly what it was supposed to do. When you got off the seat something like the pto was engaged, the HST pedal was touched or its switch not properly adjusted.
In your description you should be clearer. 'will not start back up." does this mean no crank or crank but not fire.
If you are going to troubleshoot these systems at the very least you need a 12 volt test light.
Dave M7040
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
