Kubota B3200 Remote Hydraulics Kit
   / Kubota B3200 Remote Hydraulics Kit #1
cajunmanham
Hammond, LA
Kubota B3200
IMG_0849.jpgI'm attempting to install the remote hydrauilics kit from Kubota. The instructions and pictures are pretty vague. I was wondering if someone has installed this kit and has a picture of the hose connections to the side of the transmissin behing the rear wheel.
Looking at the picture, I need to know connections that would be "Pressure Port" and "Power Beyond"?
Thanks...
   / Kubota B3200 Remote Hydraulics Kit #2
Looking at the picture : middle left looks like PYor BY - power beyond, middle right looks like P - pressure , top right looks like T - tank/outlet. Hope I understood your question
I think you are right, appreciate it.
Answer to how to install Kit, I removed the hard pipe hose to the 3pt hitch, one line from the new remote vavle went to the port on transmission and another went to the 3pt hitch. Teed into the rubber Tank/Return hose and that was it.
If I would have known that to add remote hydraulics, all I would have had to add was the valve, fittings, and hoses separately, it would have cost me hundreds less than the Kubota kit.
   / Kubota B3200 Remote Hydraulics Kit #5
We keep trying to tell people to do it your self and save hundreds of hard earned dollars.
Other people just say to buy the kit, it is the only way. Money talks for those that have it , and you don't necessarily get the better solution.
I thought I knew the Kubota dealership owners pretty well, I've bought over $80K worth of equipment from them over the years. He told me the only way he knows how to do it is the Kubota way, which relates to $$$$$.
I have a welder, cutting torches, and plenty of iron for fabricating any type of mount for the valve. With that some hoses and fittings, this would have been just as simple as the Kubota kit but hundreds less.
Like a lot of things in life, it's all about the money$$$$$.
   / Kubota B3200 Remote Hydraulics Kit #7
You think that your dealer just wants the money, says that he only knows how to do it the Kubota way. I would venture to say that he is telling you the truth. He didn't say that it couldn't be done another way, just that he only knows how to do it the Kubota way. I would say the dealer would have to charge you more money to use after market parts vs the Kubota parts. After all, he would have to charge you for all the research time, design time and custom fabrication to get this all done. To have the dealer do this, it may actually be cheaper for the customer to have the Kubota kit. I don't know of to many businesses that like to work for free, someone has to pay the guy doing all the work.
Now when you do all the work, you just saved all the time that you don't have to pay for. That is where the saving is, not in the parts. Yes the Kubota parts may be more money than the generic after market parts are, but you are paying for parts that are built for that tractor, not 1000 other machines that "it will work on". ;)
Just my :2cents:
   / Kubota B3200 Remote Hydraulics Kit #8
I don't necessarily agree in the fact that the parts in the kits are better. and made for the tractor.
They probably use the same manufacture of parts that the owner could purchase, valves, hoses, fittings, electrical.
By the time an owner has rounded up all the parts and installed same, the workmanship is probably as good as the dealer, and the owner has the satisfaction, of saying I did it and I learned something.
The only advantage in the kits, is the assembly may go together with out any fuss, and doesn't have to measure and make the hose sets, etc.
Some people never do things for themselves, and rely on other people to round up the parts and do the labor, and they feel that the pkg is worth it.
Any common sense person with a little knowledge of mechanics and hyd in general could redo the complete tractor. You see this being done all the time by the post on TBN and with the help of many people here passing out free advice and help.
About the only satisfaction of letting someone else do the job, is being able to say I am glad I did not have to do that, and I did not get dirty, and did really good on my golf game.
Some jobs I know I can do but I let other people do, mainly because of time.
I would encourage everyone to do it your self and have that satisfaction.
Those that don't have the time and have the money to spend, then that is probably the only way to go for them.
Time is money to a lot of people and rightly so, because it is getting harder to come by it.
To those that want to do things for themselves, more power to you.
   / Kubota B3200 Remote Hydraulics Kit #9
You are not going to go to Surplus Center and purchase a control valve and control levers that are integrated into the construction of the tractor such as the units used on the deluxe Kubota tractors. Those are purpose built valves and are built for the manufacturer for their specific requirements.
Yes, any of the OEM valves that are just bolted onto the ROPS for example can be duplicated and probably even have better valves for less money and are not really that big of a deal to install. In these situations, if the person is handy and has the tools and time, then they may be better off going the aftermarket route. ;)
Well, I am pretty handy and since I put this kit on myself although it wasn't easy, it wasn't that difficult either. I know the Remote Kits that Kubota sells aren't manufactured by Kubota but by a third party here in the U.S.
When I inquired about this to the dealer, he acted like the only way this could be done is a different adapter valve on the tractor to allow fo an extra port. Wrong, no extra valve, just tying in to existing hydraulic lines is all that is needed. That I could have done myself if I have researched this before I committed to the kit.
Lessons learned!!!!!
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2019 KOMATSU PC290LC-11 EXCAVATOR (A51242)
2019 KOMATSU...
