Kubota b3030 hazard and head light problem
   / Kubota b3030 hazard and head light problem #1
ring3
Hello all. Forgive me if this is in the wrong section. I am having problems with my lights. The headlights wont work and the flashers/hazards wont shut off. Everything else seems ok.
Switch on dash does nothing. Hazards keep flashing, lights dont work.
I pulled the wiring for the switch on the dash. Hazards keep going.
Pulled the flasher/hazard fuse and flashers continued to flash.
Pulled main fuse and of course they stopped.
Pulled the flasher/hazard relay and they stopped.
My tractor does not have a cab. No turn signals etc....
In my case I could care less about the hazards. dont need or use them. Always bumping the darn switch with my knee turning them on unintentionally.
I am trying to determine the issue. Bad relay? Bad wire? Bad something else? Not going to pay $80+ for a relay I dont need. Looking for suggestions and thoughts on the problem considering my situation.
Thanks
   / Kubota b3030 hazard and head light problem #2
Thanks
Let me give you a method to approach a problem like yours.
Without a wiring diagram and a troubleshooting section, your likelyhood of success is low.
Google tractordata.com Kubota B3030 spec.
You will see the model preceding your 3030 and the one after. In your case B3350 & B2630
Now go to kubotabooks.com and see if you can find a workshop manual or an owner's manual with a wiring diagram for your model or the other two.
I think the answer will be no but you need to approach future problems in the same way.
This next link will take you to a site where for $10 you can download a high quality WSM for your tractor
Kubota B3030 Tractor Workshop Manual PDF Download
I have bought several of their manuals in order to help other forum members and this is why I recommend their stuff. It is not fuzzy photocopied a dozen times crap.
Consider joining the Orange forum which deals only with Kubota's
Kubota Talk - OrangeTractorTalks - Everything Kubota
Searching on that forum is far more likely to give you needed info.
Often, rodents chewing on wires behind the dash is the cause as the bare wires with chewed off insulation start touching each other and weird things happen.
Dave M7040
Thanks for the info Dave.
Rob
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A48081)
2019 Ford F-350...
2008 John Deere 3520 Tractor (A50860)
2008 John Deere...
2025 Swict 72in Bucket Skid Steer Attachment (A49346)
2025 Swict 72in...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
2016 Freightliner Gradall D152 Truck Mounted Excav (A50860)
2016 Freightliner...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A48082)
2022 Forest River...
