Kubota B2920
/ Kubota B2920 #1
jjmjones
Western Massachusetts
Kubota B2920
Looking to take the plunge and buy new. Need to rough cut about 4 acres of hilly field. Also want to be able to move some split firewood from time to time and clean up a little after the plow goes through.
Looking at a B2920 HSD R-4 with a LA364 ldr and a 4' Landpride mover. Priced out at $16,100 for the machine and another $1500 for the deck with a clutch.
Thoughts on the machine? Price?
Thanks
/ Kubota B2920 #2
hello, i was given price on b2920 with 51in. front blower, and fel for $21000. ihope this helps, i dont know where u are located, but value implement in baldwin, Wisconsin has the best prices around!!!!!!!!!!:thumbsup:
/ Kubota B2920 #4
I have had a 2920 for about 3 years. During the winter, I use it to clear the driveway of snow using the FEL and a rear blade. I don't have chains on the R4 tires, but still never have a problem unless I get a wheel off of the raised rock drive.
I mow our yard some with it using the MMM, but also have a JD garden tractor, so usually use it on the yard. But the MMM does a good job of mowing.
We bought the B2920 primarily for another 12 acres that we have that is recreational land it is about half woods and half fields. I have a 5' Bush Hog brand mower. A 54" would have probably been a better size, but other than if I have gotten way behind on mowing, it goes through it pretty easily. The negative about using the B2920 with a rotary mower is the 1/4" valve. You can set the mower at the height you want, but as you mow, it will gradually sink down in the front so you have to bump it up. I now put chains on mine to maintain the height I want. For the other things I do, the 1/4" valve works fine.
For that reason, if you are going to do a lot of cutting with a rotorary mower, you might want to also consider a B2630 or B3030. They have some nice features including position control which will hold the mower at the desired height. But they are likely to cost a bit more.
JD has position control on their similar size tractors, but I think they have 2 range HST and I really like the 3 ranges on the B2920.
All in all, it has been very reliable and makes a great $20K wheel barrow.
/ Kubota B2920 #5
I bought mine a year ago next month, and paid $15,300 for the tractor/loader. I also got a 60" MMM for another $2350. I mow a little over 4 acres, and the tractor does about 3 acres of that (the other gets mowed with my old Dixon ZTR). I love the tractor, but the lack of position control can be a pain. I plan to get a rear rotary mower this year for occasional use on a 10 acre field that's normally rented out for crops. I guess I'll use chains to keep it in place. On the other hand, to get position control (BXX30 series) I would have had to give up the floating MMM...and it gets used probably more use than anything that hangs on the 3PH.
/ Kubota B2920
Curious about the 54" being better size. Had problems with using the 5' Bush Hog on this machine?
/ Kubota B2920 #7
No actual problems. I talked to my dealer before buying the rotary mower and he felt the 2920 would handle the 60" fine. I took my tractor to the dealer and tried the 5' Bush Hog Squeeler on it. The Squeeler is a medium weight mower and it seemed to fine with it. The had a Razorback available which is a light weight, but I stuck with the 5' Squeeler. I keep the FEL on when mowing as a counterbalance, but it is a big mower back there. Last year due to some Spring rains, I did not get to mow as ealy as I normally do, so it was pretty tall the first time I mowed and had to slow down and occasionally stop to let it catch up. Normally, I have no problem.
Sometimes when I have mowing it more regularly I just use the MMM. The MMM is really pretty robust and as long as you keep it out of brush and rocks, it is a pleasure to mow with it. I would agree with Fred's comment that I like the suspended mower on the B2x20 better than the ground contact mowers used on the Bxx30's.
/ Kubota B2920
Dealer is suggesting a Land Pride deck for the B2920-I think that's the line that Kubota has a relationship with. Any thoughts on that product line?
/ Kubota B2920 #9
I think Land Pride is very good. I would have no problem with their products and have a rear blade made by Land Pride. My dealer gets some of theirs, but hadles more Bush Hog brand. They would have gotten the Land Pride for me, but I was ok with the Bush Hog and at that dealership it was a bit cheaper due to their volume of Bush Hog vs Land Pride.
/ Kubota B2920 #10
I started out with a cheap light weight rear finish mower and it kept breaking. After a year of use Barlows gave me what I paid for it ($1200) toward a Landpride RFM ($1700). The Landpride was quite a bit heavier and was built like a tank. Never broke it a single time.
In seven years of tractoring I've found out or determined that weight makes a big difference. If there is a choice I go with the heavist piece of equipment (Implement) I can afford and that my tractor will handle.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2016 John Deer 5075E (A60462)
2016 John Deer...
