Mowing Kubota B2650 not enough power for FDR2572 mower?
   / Kubota B2650 not enough power for FDR2572 mower?
The 7% figure is from an email to Kubota. I'm well aware of the way an HST works, if I was holding it to the floor in mid range it would simply stall the engine. I modulate the HST input to keep it running.
   / Kubota B2650 not enough power for FDR2572 mower? #22
If my reply came across as harsh, I didn't mean it to.
No, I was just making sure that we all understand each other
   / Kubota B2650 not enough power for FDR2572 mower? #24
Rock Crawler,
How are things going w/ the you tube channel,? I did subscribe but need to ad a like more often . I have a small ford, 21.5 pto hp. My grades are not quite as steep as yours but a challenge, For years I used my 90 inch Walco finish mower behind that tractor, It worked, would work today if necessary. At times low range was necessary, if I neglected a cut cycle, I would hold more a little high and make two passes, but it always cut the grass. Opinion: downsizing not the answer. 1/2 uphill in low 1/2 downhill going like the wind, like rock crawlers, right, good luck this season.
Majorwager,
I truly suck at YouTube and doing video editing! That's why a lot of my videos are not edited... I bought a couple programs thinking that if a spent a couple hundred dollars, it would make everything quick and easy. Not the case! I bought VideoPad Video Editor and also HitFilm4, after buying them I tried to fight my way into them, but I'm just too computer stupid
So I use that one built in to Windows if I edit at all... I prefer to just got record and walk around talking to the camera or setting down where it can watch me, and then just upload it as it is. Lame, I know.
I had considered monetizing the account, but for that you have to be able to produce video that humans will watch... And again... I'm just not that guy. Plus it takes a lot of time that would keep me from going out playing on rocks, cutting wood and creating my Oasis camp in my back woods. I hate video editing!
   / Kubota B2650 not enough power for FDR2572 mower? #26
Amen Rock Crawler !!! I have been all over the place trying to find a SIMPLE, USABLE video editor. Something one could remove a time slice, add a time slice, do titles and annotation. There has to be huge demand for that and I cannot find it at all. Have tried several. Either they do not work, are so illogical and crazy, so limited in features or just flat worthless. Easy to find for still photos, very allusive for videos ! And by the way I was in the computer related technology business for more than 40 years.
Believe me it is NOT your computer stupidity, it is the video software industry stupidity.
I guess that's why you and I will not be making $150,000 year producing tractor videos likely Wranglerstar and Outdoors With the Morgan's
   / Kubota B2650 not enough power for FDR2572 mower? #28
I run a 72" rfm wirh my 20 hp (16hp pto) massey. I go slow up my steep hill.
   / Kubota B2650 not enough power for FDR2572 mower? #29
You have about the heaviest combination you could on that tractor with a reduced final gearing and running a mower that's I imagine is larger then the recommended size on decent hills.
I think you are asking too much for a 26hp tractor.
What is your altitude?
Also is there any more throttle or do you have it maxed out?
Maxed out throttle, 900 foot elevation.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
Rolling Drain Pan, 44" x 27" w/Pump to Drain (A59076)
Rolling Drain Pan...
Brock Meyer 2000S 70'x12' 2000 BPH Grain Dryer (A57148)
Brock Meyer 2000S...
