Kubota B2650 and B3350 info and hints
   / Kubota B2650 and B3350 info and hints
The stock parking brake warning light is not bright enough to overcome bright sunshine, senility, and not paying enough attention. I installed a bright LED panel light in parallel with the original light on my B3350.
On a B2650, one could order the original Kubota parts and bracket for the B3350, I'm sure they'd fit, or go on the cheap and install a roller microswitch using a sheet metal bracket etc to get it into an appropriate position.
Amazon.com: Micro Limit Switch Long Hinge Roller Lever Arm SPDT Snap Action LOT: Computers & Accessories
Lee,
Have you had the most recent software upgrade recall done yet? It was from back in November of 15 I think. In any case, my B3350 originally defaulted to "no auto-regen" at start up. So like you, I was in the habit of pressing the far right button to enable auto-regen (on the fly at more than 2000 rpm). After the last upgrade, that procedure was reversed without telling us. No it defaults (like the newer B3350's) to auto-regen enabled.
You cannot (or at least I cannot) do a parked regen unless the system is asking for one (parked regen light on the panel flashing. Then, if I have difficulty gettng parked regen to start, this has worked for me. Make sure all do-dads are off PTO off etc (my seat switch is bypassed so mine will run with PTO going and me not sitting in there). Shut off tractor, put parking brake on. Put tranny range selector in N position. Re-start and make sure throttle is all the way to idle, push parked regen button. Parked regen light should come on and engine RPM should smoothly go up to 2000 rpm. Go have a cup of coffee or something waiting for the engine to return to idle. During this whole process you cannot do anything to or with the tractor - don't touch the throttle etc.
Note, when it finishes, it it'll keep on running at idle, loading up the DPF again - really stupid. Kubota should have programmed it to shut down by itself after a parked regen- DUH.
   / Kubota B2650 and B3350 info and hints #223
Bumperm,
thanks for the info on the software upgrade. I have a call to the dealer and will find out.
I did get it to do a parked regen this morning. Must be operator error or getting familiar with the procedure. The only thing I did differently than the other day (I had everything parked, and in neutral as you suggested) was to start with the throttle all the way down. The manual referred to "idle speed" but I really didn't know if that meant all the way down.
Thanks for the info. It was a big help.
   / Kubota B2650 and B3350 info and hints #224
I asked my dealer if he about the switch in the auto gen button and he didn't know about it. I haven't regenerate since the upgrade as we are between seasons. Guess I won't push the button and see what happens.
   / Kubota B2650 and B3350 info and hints #225
Hello everyone,
I am a new 2650 owner and I did not initially realize that there were multiple tiers, stages, or ratchets? of parking brake locking. I am not near my tractor during the week, so I thought I woudl ask while I remember. I also did not see anyone mentioning this in the thread... So:
How does the parking brake locking mechanism work? Are there say 3 levels of locking, does it have an unlimited amount of degrees of freedom where it can lock, or something else?
   / Kubota B2650 and B3350 info and hints #226
Basically, the brake lever will lock the pedal however far you push the pedal, give or take some range with each increment in the pawl. It's just a bunch of teeth that can catch. You can look underneath and see it all.
   / Kubota B2650 and B3350 info and hints #227
Thanks for the response, I shall take a look this weekend.
Another question:
Is anyone aware of the ability to get wider front tires? Alternatively, I have seen pictures of tractors that have double tires on their front axles. I do not recall any photos of a B26/3350, but I imagine the principle is the same.
The B2650 doesn't have a parking brake on warning light, the B3350 does, but I find it easy to miss, especially in bright sunlight. If the tractor is driven with the parking brake on it will result in rapid wear of the brake friction material. Unfortunately, these parts of the system are within the tractor case, so relatively expensive to repair.
After goofing a couple of times, I installed bright LED warning light in parallel with the existing light on my B3350.
A buzzer could be used too, but some additional wiring would be needed to keep the buzzer from driving you nuts during warm up or whenever working on or around the tractor when it's running and the parking brake is on. There's a fix to make a buzzer more user friendly, only sounding when you are seated in the tractor, the engine is running, and the parking brake is on.
I already have my seat/PTO safety switch disabled (and I do not recommend that others do such a stupid thing!!) I did this as whenever I mow and twist in the seat or go over a bump, or take my weight off the seat for any reason, the engine dies. Dumb. I unplugged the seat from the wiring harness and plugged in a little wire jumper to short the two pins in the harness plug. My tractor is now happy even if I bounce up and down while mowing. AND, my seat switch is currently unused. If I wire the seat switch in series with the parking brake warning buzzer, it won't sound until I am seated. It's on my to do list.
   / Kubota B2650 and B3350 info and hints #229
Bumperm,
Is it possible to take a picture of your parking brake brake and switch bracket ? I may already have the bracket on my 2650 and I can't tell from the WSM. I tried to look up the bracket part number on the parts list but couldn't locate it. I'm guilty of leaving the parking brake on.
Thanks,
Randy
   / Kubota B2650 and B3350 info and hints #230
Having forgotten to release the parking brake a couple times already, I had a look while the panel was off doing other wiring for flood lights. There's a switch mounted on a bracket for the parking brake lever, guessing it's for using the PTO or something? My plan is to wire up a LED warning lamp using the existing switch if possible. Buzzer may be a good idea if tied into the seat switch as described by Bumperm.
   / Kubota B2650 and B3350 info and hints #231
KyleH - Let us know how it goes, some photos would be great also on adding the brake light. I have not yet taken the panel off and looked under there now the good weather is here. I hope to do so when I get it back from the 50 hours service. I bought an LED strip that I want to mount to the left of the console on the window too blink as a reminder.
:eek: Opps... got to update my profile from my B2920 to the B2650 cab....
   / Kubota B2650 and B3350 info and hints #232
Will do, been too busy using the tractor to do any upgrades lately, thinking a flashing led would be more noticeable than a solid one.
   / Kubota B2650 and B3350 info and hints #233
I have been reading this and other topics on the B 2650/3350 and all the info seems to be about a year old. I am looking at both models and was wondering if some of the bugs for the regen has been worked out of the 3350. I only have 2 acres but plan to buy more later. Also the dirt/clay here is very hard when it drys. I want a tractor that is going to be able to till the dirt so I can smith out my yard over a few years. I just don't want to buy a tractor that is to small for the job but don't want one that I have to keep messing with all the time to get it to work. What would you guys suggest. This will be my first tractor. My neighbor has a 32 hp John Deere and it seems pretty good I just don't like how John Deere makes you pay a premium for there stuff if something breaks. Also I want to put a MMM and mow my yard.
The altitude I live at 4,800 feet and hot in the summer (desert), pushed me to the 3350, as its turbo takes care of the power loss at altitude (about 3% for every 1000 feet). If altitude isn't a factor, I'd recommend the 2650. I've had no real issues with my tractor, but, not being able to use it at low rpms, and the potential for DPF issues weigh heavily. I had a 24 Kubota years ago and never needed more power - sometimes you go just a little slower as when brush cutting with a rotary mower, but it gets the job done.
I agree with you on the John Deere thing. They did not stand up and do the right thing for all their rotary mower failures where the output shaft is shearing and leaving the blades sitting on the ground!
   / Kubota B2650 and B3350 info and hints #235
More power is usually better, but went with the B2650 because there's no emissions to worry about. So far there's only been a couple times a little more power would be nice, such as uphill in high gear which is rare anyways for me. Since they are HST you just have to slow down a little.
Have been doing a little research about adding a turbo onto my B2650, talked to some diesel shops that said 4-5 psi of boost would be safe and put it around 34-35hp with a lot more torque. Still deciding if it's even needed...
   / Kubota B2650 and B3350 info and hints #236
Dude. Keep us posted on the turbo. That would be bad ***. I have a turbo from a cat laying around. It might be a little big but that would be an awesom project and be pretty cool.
   / Kubota B2650 and B3350 info and hints #237
When I picked up a 3point trailer hitch receiver from my dealer, I was in a rush, but I heard a salesman say that the 3350 was a stop sale in Ontario due to the cold weather performance with the dpf and regeneration in this climate. I cannot say much more about it, as that is all that I heard
   / Kubota B2650 and B3350 info and hints #238
There was a stop sale on the B3350 when I was buying last fall, not sure if they have it figured out, one guy mentioned they have a cover for the rad to keep the temps up during the winter.
   / Kubota B2650 and B3350 info and hints #239
Will do, will likely be a while doing research and gathering parts, it's not easy finding people that sell turbos that will take the time to answer questions but believe I have found somebody that knows what they are doing and willing to help. Which is why I will be buying from them.
The turbo needs to be fairly small to spool up quick enough, which is easy enough to find, but the wastegate needs to be adjusted down to 4-5 psi to be safe.
So far it looks like the IHI RHF3 will be the best choice being liquid cooled and ball bearing it will spool quick and be durable. Cat does use this same turbo for some of its applications. I'd have to look up the part number again.
I don't want it to look like a hack job when finished either, so I am going to take my time and fabricate it as neatly as I can. Hopefully it will have room right off the manifold since the B3350 has one along with the dpf over top of the engine.
   / Kubota B2650 and B3350 info and hints #240
I look forward to copying you lol
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
CAT930K (A58214)
CAT930K (A58214)
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2844 (A58376)
2844 (A58376)
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
