Kubota b2620 leaking Head Gasket
/ Kubota b2620 leaking Head Gasket #1
mike paulson
Bronze Member
Only 370 hrs on a five yr old B2620 that has been maintained and babied and absolutely never overheated. I open the oil drain plug and get about a shot glass worth of coolant after a good sit. Must be really slight because I haven't had to add coolant to radiator or overflow. Called Kubota and asked them if this is something common for this little 3 banger and was told it's unheard-of. Also asked for an estimate and was quoted 1500 hundred bucks which pretty much says I'll be doing this myself.
So anyone out there experience this or heard of this? Just wanna check all bases before I pull this apart. Any info on needing the head milled or spots to check in the block. Thanks in advance..
/ Kubota b2620 leaking Head Gasket #2
Post again in the Kubota Owning/Operating Forum for better results.
Good Luck!
/ Kubota b2620 leaking Head Gasket #3
A new head gasket may fix the problem, or it may not. Further investigation into possible sources of the problem are warranted. Is there any other path for coolant to enter the lubrication system?
/ Kubota b2620 leaking Head Gasket #4
Is there an oil cooler
/ Kubota b2620 leaking Head Gasket #6
Check the oil filter assembly for oil cooler built into it
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
Deere 335P (A53317)
Deere 335P (A53317)
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
