Kubota b2620 leaking Head Gasket
/ Kubota b2620 leaking Head Gasket #1
mike paulson
Only 370 hrs on a five yr old B2620 that has been maintained and babied and absolutely never overheated. I open the oil drain plug and get about a shot glass worth of coolant after a good sit. Must be really slight because I haven't had to add coolant to radiator or overflow. Called Kubota and asked them if this is something common for this little 3 banger and was told it's unheard-of. Also asked for an estimate and was quoted 1500 hundred bucks which pretty much says I'll be doing this myself.
So anyone out there experience this or heard of this? Just wanna check all bases before I pull this apart. Any info on needing the head milled or spots to check in the block. Thanks in advance..
/ Kubota b2620 leaking Head Gasket #2
Post again in the Kubota Owning/Operating Forum for better results.
Good Luck!
/ Kubota b2620 leaking Head Gasket #3
A new head gasket may fix the problem, or it may not. Further investigation into possible sources of the problem are warranted. Is there any other path for coolant to enter the lubrication system?
/ Kubota b2620 leaking Head Gasket #4
Is there an oil cooler
/ Kubota b2620 leaking Head Gasket #6
Check the oil filter assembly for oil cooler built into it
2025 32in Bucket Mini Skid Steer Attachment (A59228)
2025 32in Bucket...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2017 Kustom Signals Towable Solar Radar Speed Limit Trailer (A59228)
2017 Kustom...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
