Kubota B26 hoe
/ Kubota B26 hoe #1
stso9d
Cabot, ar
Kubota b26
I have a Kubota B26 that I purchased used. I am changing the filters and hydraulic fluid in the reservoir. I cannot find how much fluid it requires (capacity). I added 5 gallons, but it still doesn't show on the stick. Plus I can reason that the reservoir looks larger than 5 gallons...
Thanks for any replies...
Randy
:confused3:
/ Kubota B26 hoe #2
I also have a B26 and thought I could help but it's nowhere to be found in my manuals or on line.
Might have to contact your dealer.
Good luck.
/ Kubota B26 hoe #3
How much did you drain out?
Add a litre at a time, until it shows on the dipstick - then half-litres until it shows full. Record the total amount in your manual and write it on the machine somewhere for future reference.
Plus post it here for kwanwons benefit too.
/ Kubota B26 hoe #4
Call a dealer. They have all that information. They are able to look it up to advise customers how much oil to buy and such
/ Kubota B26 hoe #5
L39 takes 11 gallon.
Regular B take about 5 gallons.
B26, Figure two 5 gallon pails and you will have extra.
/ Kubota B26 hoe #7
Yes, you are exactly right. Thank you!!!!!!!!!!!!!!!!!!!
Might I add that you put some red dye in the hyd fluid. Makes it so much easier to see, plus if you have any leaks you can pinpoint them too.
I use John Deere #MT3668, cost about 7 dollars.
/ Kubota B26 hoe
I learn something every day! I do have a small leak I need to isolate. Thank You!
/ Kubota B26 hoe #9
When I have a small leak, I try to ignore it. I figure oil protects against rust. I have a few weeps. Nothing a rag doesn't clean up.
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2022 EZ-GO ELITE...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2003 Ford F-550 Pickup Truck (A66408)
2003 Ford F-550...
AGroTK ATK-WB24A (A64127)
AGroTK ATK-WB24A...
