Kubota B26 hoe
/ Kubota B26 hoe #1
stso9d
Cabot, ar
Kubota b26
I have a Kubota B26 that I purchased used. I am changing the filters and hydraulic fluid in the reservoir. I cannot find how much fluid it requires (capacity). I added 5 gallons, but it still doesn't show on the stick. Plus I can reason that the reservoir looks larger than 5 gallons...
Thanks for any replies...
Randy
:confused3:
/ Kubota B26 hoe #2
I also have a B26 and thought I could help but it's nowhere to be found in my manuals or on line.
Might have to contact your dealer.
Good luck.
/ Kubota B26 hoe #3
How much did you drain out?
Add a litre at a time, until it shows on the dipstick - then half-litres until it shows full. Record the total amount in your manual and write it on the machine somewhere for future reference.
Plus post it here for kwanwons benefit too.
/ Kubota B26 hoe #4
Call a dealer. They have all that information. They are able to look it up to advise customers how much oil to buy and such
/ Kubota B26 hoe #5
L39 takes 11 gallon.
Regular B take about 5 gallons.
B26, Figure two 5 gallon pails and you will have extra.
/ Kubota B26 hoe #7
Yes, you are exactly right. Thank you!!!!!!!!!!!!!!!!!!!
Might I add that you put some red dye in the hyd fluid. Makes it so much easier to see, plus if you have any leaks you can pinpoint them too.
I use John Deere #MT3668, cost about 7 dollars.
/ Kubota B26 hoe
I learn something every day! I do have a small leak I need to isolate. Thank You!
/ Kubota B26 hoe #9
When I have a small leak, I try to ignore it. I figure oil protects against rust. I have a few weeps. Nothing a rag doesn't clean up.
2022 Belshe WB14 18ft  12000lb Trailer (A64047)
2022 Belshe WB14...
PROPANE TANK (A63569)
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
