Kubota B2400 HSD Hydraulic leak at back of bell housing
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #1
davesvo
Has anyone replaced the seal that goes in the back of the bell housing where the shaft comes out to go back to the transmission? Just wondering if The shaft comes out without splitting the tractor? I have a pretty good leak developing and need to replace the seal, really hoping not to have to splint the machine.
-Dave
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #2
What did you end up doing?
Ended up the seal was ok . It was the plug above the seal that was leaking. 2 min and a screwdriver fixed that one.
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #4
They are a royal pain to access - my neighbor had same issue - like you said - long screwdriver flips the old one out real easy, getting the new one in is gymnastics with your fingers and a pry bar.
My B21 has the same seal - knock wood its still tight (and it has more pipes and frame in the way so even harder to get to than yours or the B series)
Glad iot worked out OK.
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A51572)
2007 Ford Crown...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
