Kubota B2400 HSD Hydraulic leak at back of bell housing
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #1
davesvo
Has anyone replaced the seal that goes in the back of the bell housing where the shaft comes out to go back to the transmission? Just wondering if The shaft comes out without splitting the tractor? I have a pretty good leak developing and need to replace the seal, really hoping not to have to splint the machine.
-Dave
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #2
What did you end up doing?
Ended up the seal was ok . It was the plug above the seal that was leaking. 2 min and a screwdriver fixed that one.
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #4
They are a royal pain to access - my neighbor had same issue - like you said - long screwdriver flips the old one out real easy, getting the new one in is gymnastics with your fingers and a pry bar.
My B21 has the same seal - knock wood its still tight (and it has more pipes and frame in the way so even harder to get to than yours or the B series)
Glad iot worked out OK.
Unused Delta Crash...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
Electric Concrete Mixer (A51573)
Electric Concrete...
