Kubota B2400 HSD Hydraulic leak at back of bell housing
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #1
davesvo
Has anyone replaced the seal that goes in the back of the bell housing where the shaft comes out to go back to the transmission? Just wondering if The shaft comes out without splitting the tractor? I have a pretty good leak developing and need to replace the seal, really hoping not to have to splint the machine.
-Dave
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #2
What did you end up doing?
Ended up the seal was ok . It was the plug above the seal that was leaking. 2 min and a screwdriver fixed that one.
   / Kubota B2400 HSD Hydraulic leak at back of bell housing #4
They are a royal pain to access - my neighbor had same issue - like you said - long screwdriver flips the old one out real easy, getting the new one in is gymnastics with your fingers and a pry bar.
My B21 has the same seal - knock wood its still tight (and it has more pipes and frame in the way so even harder to get to than yours or the B series)
Glad iot worked out OK.
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
DRIVELINES (A50854)
DRIVELINES (A50854)
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
