Chains Kubota B2320 trailering
   / Kubota B2320 trailering #1
Engine Mike
Rochester hills michigan
Kubota B2320
I need to trailer my Kubota B2320 for the first time. I am looking for advice for tieing the tractor down securely. Also wondered if anyone knows where I can purchase front tie down brackets. Or is there a better way to tie down the front?
   / Kubota B2320 trailering #2
I tie mine down with chains, right to the trailer 'pockets'. Get her real tight; you'll need a big cheater bar. ImageUploadedByTractorByNet1470670491.428398.jpg
   / Kubota B2320 trailering #3
I use the 4" wide straps across the 3ph in the back and across the front grill plate with no cheater bar. If FEL on I strap across the arms behind the bucket.
The straps have ratchet handles that tighten them down. Lots of opinions on straps vs chains but i've used the straps for at least 10 years with no issues and now no concerns. I don't haul any thing heavier than a L size Kubota with implements (6000 lbs) but I doubt it would make a difference to me. Lots of big tractor trailers on the hwy using straps and not chains.
14-17.5 Tires (set of 4) (A49251)
14-17.5 Tires (set...
2018 Volkswagen Atlas SE SUV (A48082)
2018 Volkswagen...
Hanson 2 Wheel Sprayer Stainless Steel Tank (A49339)
Hanson 2 Wheel...
2025 JMR 40in Grapple Rake Mini Skid Steer Attachment (A46683)
2025 JMR 40in...
2011 Mercedes-Benz E-Class 350 Sedan (A46684)
2011 Mercedes-Benz...
2006 Sterling Acterra Terex BT3470 Knuckleboom Crane Truck (A46683)
2006 Sterling...
