3-Point Hitch Kubota B21
/ Kubota B21 #1
mba
Mooresville, NC
Kubota B21
I have a 2003 Kubota B21 that has always been a loader backhoe. I want to start using it for general landscape work at my house. Are there sources for all of the three point hitch conversion parts necessary after I remove the backhoe? What size box scrape and pulverizer would work best with this size tractor?
/ Kubota B21 #2
I am in the same boat and have been looking for a 3pt kit for my B21. From a search of the forums it looks like a kit from a B26 will fit. Here is a 2010 quote from BruceWard:
If you are interested in getting the official Kubota parts, there is a 3 point hitch kit for the B26 that will fit the B21 and costs about half the price of ordering the B21 parts individually. The 3 point kits part number is B3941.
I tried searching for the kit on Messick's and TractorSmart but did not get a hit and my dealer had no record of it. Please post back if you are successful. Good luck. Here are the links to past discussions:
http://www.tractorbynet.com/forums/kubota-owning-operating/185907-kubota-b21-3-lift.html
http://www.tractorbynet.com/forums/kubota-owning-operating/166628-b21-top-link-lift-arm.html#post1912129
P.S.- I am planning on getting a 4' Gannon.
/ Kubota B21 #3
My B21 came with the 3pt parts stored up on the loader frame.
The 3 pt capacity is fairly low. The manual's max specs for a box blade: 42" wide, 375#.
Ken
/ Kubota B21 #4
I happen to have a Kubota Wholegoods catalogue from 2009 and it does show a kit B3941 as being the 3PH parts for the B26. Being a wholegoods item, you would have to order it through the dealer's sales office and not parts. If you only checked with the parts department, that may be why they couldn't find it for you. Hope this helps some and good luck to you both.
By the way, list price back then was $393.
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
Gradall no crank no start (A61568)
Gradall no crank...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
