3-Point Hitch Kubota B21
/ Kubota B21 #1
mba
Mooresville, NC
Kubota B21
I have a 2003 Kubota B21 that has always been a loader backhoe. I want to start using it for general landscape work at my house. Are there sources for all of the three point hitch conversion parts necessary after I remove the backhoe? What size box scrape and pulverizer would work best with this size tractor?
/ Kubota B21 #2
I am in the same boat and have been looking for a 3pt kit for my B21. From a search of the forums it looks like a kit from a B26 will fit. Here is a 2010 quote from BruceWard:
If you are interested in getting the official Kubota parts, there is a 3 point hitch kit for the B26 that will fit the B21 and costs about half the price of ordering the B21 parts individually. The 3 point kits part number is B3941.
I tried searching for the kit on Messick's and TractorSmart but did not get a hit and my dealer had no record of it. Please post back if you are successful. Good luck. Here are the links to past discussions:
http://www.tractorbynet.com/forums/kubota-owning-operating/185907-kubota-b21-3-lift.html
http://www.tractorbynet.com/forums/kubota-owning-operating/166628-b21-top-link-lift-arm.html#post1912129
P.S.- I am planning on getting a 4' Gannon.
/ Kubota B21 #3
My B21 came with the 3pt parts stored up on the loader frame.
The 3 pt capacity is fairly low. The manual's max specs for a box blade: 42" wide, 375#.
Ken
/ Kubota B21 #4
I happen to have a Kubota Wholegoods catalogue from 2009 and it does show a kit B3941 as being the 3PH parts for the B26. Being a wholegoods item, you would have to order it through the dealer's sales office and not parts. If you only checked with the parts department, that may be why they couldn't find it for you. Hope this helps some and good luck to you both.
By the way, list price back then was $393.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
