Snow Kubota B21 under snow drift won't start
   / Kubota B21 under snow drift won't start #21
Another method that's pretty sure to work when everything is cold, slow, and stiff is to give the air intake a sniff of starting fluid. If it turns over at all a little shot usually gets it done. I keep a can on hand - I never use much of it (like 1/2 second spray)
   / Kubota B21 under snow drift won't start #22
Ya got it figured out, but if it is slow to trun over again, do you have a compression release?
My B8200 is very similar to the B20/B21. I have a compression release knob I can pull. My battery went bad a few years back. Even with a weak charge, if I let the motor start spinning with no compression, it would fire when I released the compression realease.
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2020 JLG SKYTRACK 12054 TELESCOPIC FORKLIFT (A60429)
2020 JLG SKYTRACK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
