Kubota B20 3 Pt. Hitch too Narrow
   / Kubota B20 3 Pt. Hitch too Narrow #1
phojes
Houston
Kubota B20
I have a B20 with the 750 backhoe on it. Last week I removed the backhoe for the first time and tried to put a box blade on the 3 pt. hitch. The arms are way to narrow!
My lift arms only spread 18.5 inches (normal is bout 26 inches). The lift arms seem to be hitting on the rops where it bolts to the tractor. Anybody else had this problem on a B20 or have any idea of how I can work around this?
THANKS!
Joe
   / Kubota B20 3 Pt. Hitch too Narrow #2
Can you provide some pictures?
Thanks for the link!
I will check to see if they are on backward and take some pictures when I am back out where the tractor is on Saturday.
   / Kubota B20 3 Pt. Hitch too Narrow #5
I just came across the same problem. I purchased a post hole drill from Tractor Supply, disconnected the backhoe (first time it has been off in 20 years so you can imagine the fun) and found to my dismay that the lower arms would not spread wide enough to fit the wishbone from the new posthole drill. [and they are not on backwards] Same problem, the lower arms hit the frame of the ROPS. I was considering removing the ROPS, however the pin for the low arms is part of the ROPS!!! Anyone have a solution short of bending the lower arms so that they fit the wishbone??
Bob
   / Kubota B20 3 Pt. Hitch too Narrow #7
You can reverse the pins on the implement in such a way that they point inward instead of outward. This will get you a couple of inches. I've done this with post hole digger successfully.
Mike
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
Assortment of Pipes (A50121)
Assortment of...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
2013 Kidd 450 Straw Chopper (A50774)
2013 Kidd 450...
New Giyi Dingo Backhoe (A50774)
New Giyi Dingo...
