Kubota B20 3 Pt. Hitch too Narrow
   / Kubota B20 3 Pt. Hitch too Narrow #1
phojes
Houston
Kubota B20
I have a B20 with the 750 backhoe on it. Last week I removed the backhoe for the first time and tried to put a box blade on the 3 pt. hitch. The arms are way to narrow!
My lift arms only spread 18.5 inches (normal is bout 26 inches). The lift arms seem to be hitting on the rops where it bolts to the tractor. Anybody else had this problem on a B20 or have any idea of how I can work around this?
THANKS!
Joe
   / Kubota B20 3 Pt. Hitch too Narrow #2
Can you provide some pictures?
Thanks for the link!
I will check to see if they are on backward and take some pictures when I am back out where the tractor is on Saturday.
   / Kubota B20 3 Pt. Hitch too Narrow #5
I just came across the same problem. I purchased a post hole drill from Tractor Supply, disconnected the backhoe (first time it has been off in 20 years so you can imagine the fun) and found to my dismay that the lower arms would not spread wide enough to fit the wishbone from the new posthole drill. [and they are not on backwards] Same problem, the lower arms hit the frame of the ROPS. I was considering removing the ROPS, however the pin for the low arms is part of the ROPS!!! Anyone have a solution short of bending the lower arms so that they fit the wishbone??
Bob
   / Kubota B20 3 Pt. Hitch too Narrow #7
You can reverse the pins on the implement in such a way that they point inward instead of outward. This will get you a couple of inches. I've done this with post hole digger successfully.
Mike
2019 Doosan LCV6 Towable Light Tower (A51691)
2019 Doosan LCV6...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2003 Scag Tiger Cub Zeroturn (RUNS) (A50774)
2003 Scag Tiger...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
