Kubota B1700 odd starting problem
   / Kubota B1700 odd starting problem #1
JustAGuy
Clarkrange, TN
Kubota B1700
Good day everyone,
I have a Kubota B1700 with an unusual starting issue. When the tractor is cold, it (usually) starts up fine with no problems. But after I have been running it a while, when I turn the key, the ignition lights come on but no engagement of the starter. No clicking and the engine does not turn over at all. It rarely does this when it is cold, but almost always does it after it is warm. When it refuses to start, I am able to turn the key on and start it with a screwdriver by jumping it at the starter. Any thoughts on what the problem might be?
Thanks in advance!
   / Kubota B1700 odd starting problem #2
Defective battery cables, corroded cable connections at ground, starter or battery, failing battery, fried key switch, failing connector at solenoid wire at starter, failing solenoid. Try to remedy one thing at a time so you'll know (and tell the rest of us) what was wrong. Sounds like a simple process of elimination.
Jim
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2003 PETERBILT 379 (A50854)
2003 PETERBILT 379...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
