Kubota B Series - Service It Yourself
   / Kubota B Series - Service It Yourself #81
Just completed 50 hr. maintenance on Kubota B2601. Thanks for this post... great help. One question though. After draining trans and hydro (3 plugs) (wow that was a lot of oil that came out) and replacing HST and Trans filter and refilling with 4 gallons of SUDT2, the oil on trans dipstick is much higher than full indicator. Should I be worried about this? Will it eventually “level out” after use? Should I drain some out? Your opinions are appreciated.
Start with the obvious.... On level ground? Make sure the dipstick was wiped off well before rechecking. Run the tractor, cycle the valves, and recheck... If still high I'd agree that you over added a bit due to the fact that you can never fully drain all the oil..
   / Kubota B Series - Service It Yourself #82
I did the same dang thing and had to drain some out to get back to the full mark on the dipstick. You don't want to operate with a high/low fluid level.
   / Kubota B Series - Service It Yourself #84
Thanks everyone for your replies. I’m going to pull a little out so it is at the proper level on dipstick.
   / Kubota B Series - Service It Yourself #85
Like many others' here.....thank you for the thread info.
I'll be doing the first 50hr service and complete fluid/filter change on my B2650 tomorrow.
The info on the hyd fluid level helps! I will see how much comes out and refill accordingly.
Thanks again!
   / Kubota B Series - Service It Yourself #86
Be very conservative when refilling. Fill it about 3/4 of what you drained out and check dipstick and add a little. Dont get it overfilled or you will consume more time getting it out. Be patient and go thru the check dipstick-add process.
   / Kubota B Series - Service It Yourself #87
A curious note on "oil fill levels"
When early Fordsons were introduced to the States from Cork, some engine failures were noted by farmers of hilly lands. THis got to be a bit of a concern, so Fordson put their best engineers to the task. After long trials and much tribulation, A "Hill Country: retrofit kit was supplied to any dealer that requested such.
The "kit" was composed of just one element.
A shortened dip stick!
   / Kubota B Series - Service It Yourself #88
Looking for the coolant change info on my B2920. Anybody know of one?
1000 FUEL TANK (A52708)
1000 FUEL TANK...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2016 INTERNATIONAL MA025 TRUCK (A56858)
2016 INTERNATIONAL...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
