Kubota 7510 remotes
/ Kubota 7510 remotes #1
PSDawg
I am installing remotes on my 7510 and need to know what size 'T' fitting is required for the tank fitting when adding a new valve. Thanks.
/ Kubota 7510 remotes #2
The tank end is 3/8" NPT. I believe there is an adapter in there when the loader valve connects directly to it. The adapter will be 3/8" NPT male to 3/8" JIC male. The loader hose is 3/8" JIC. At least that is the way it was on My B2710.
Thanks for the quick reply! Are all the other fittings JIC as well?
/ Kubota 7510 remotes #4
Why are you putting remotes on your b7510? I was woundering because that might be something I need to do.
I am adding a hydraulic top link. I thought I was finished after I added a grapple and a 12V valve earlier, but this would really be helpful with the rear attachments.
/ Kubota 7510 remotes #6
The hoses to and from the block have JIC ends too.
Thanks. I should have the valve and top link today. I will post all the required fittings when I am done.
2009 Vicon 2400 9ft. 3 Point Disc Mower (A65640)
2009 Vicon 2400...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Pair of 380/85R34 Tires (A65640)
Pair of 380/85R34...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
