Kubota 7510 remotes
   / Kubota 7510 remotes #1
PSDawg
I am installing remotes on my 7510 and need to know what size 'T' fitting is required for the tank fitting when adding a new valve. Thanks.
   / Kubota 7510 remotes #2
The tank end is 3/8" NPT. I believe there is an adapter in there when the loader valve connects directly to it. The adapter will be 3/8" NPT male to 3/8" JIC male. The loader hose is 3/8" JIC. At least that is the way it was on My B2710.
Thanks for the quick reply! Are all the other fittings JIC as well?
   / Kubota 7510 remotes #4
Why are you putting remotes on your b7510? I was woundering because that might be something I need to do.
I am adding a hydraulic top link. I thought I was finished after I added a grapple and a 12V valve earlier, but this would really be helpful with the rear attachments.
   / Kubota 7510 remotes #6
The hoses to and from the block have JIC ends too.
Thanks. I should have the valve and top link today. I will post all the required fittings when I am done.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
