Kubota 7100 HST power steering problem
   / Kubota 7100 HST power steering problem #1
Larry923
Grand Rapids,Mn
Kubota 7100 HST
I have a 96 Kubota 7100HST and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is plunger that is stuck? I was told it is a 1996 model on the hood it says power steering it is a B2100 HST 4 wheel drive How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #2
A 1996 B7100 Kubota did not come from the factory with power steering. :D
If there is power steering it is an aftermarket add on.:)
   / Kubota 7100 HST power steering problem #3
Yep, Larry, like Egon said. I bought a new one in 1995 myself. They didn't have power steering and I've never even seen an aftermarket power steering on a B7100. I've seen some aftermarket, add-on power steering arrangements on some bigger older tractors of another brand, but never for the B7100.
   / Kubota 7100 HST power steering problem #5
OK, a B2100 is a bit different from a B7100, and I don't know about that.
I have a 96 Kubota B2100 HST 4 wheel drive and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is a plunger that is stuck? How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #8
Big difference between the 7100 and the B21.
If you increase the REV's does the steering get better?
b21's are a nice machine.:thumbsup:
no it does not turn easier if reved up,it has a loader and the hydraulics on it work fine
   / Kubota 7100 HST power steering problem #10
Would it be possible to get the pump output pressure and compare it to specs?:D
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
Kawasaki NR (A50324)
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
