Kubota 7100 HST power steering problem
   / Kubota 7100 HST power steering problem #1
Larry923
Grand Rapids,Mn
Kubota 7100 HST
I have a 96 Kubota 7100HST and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is plunger that is stuck? I was told it is a 1996 model on the hood it says power steering it is a B2100 HST 4 wheel drive How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #2
A 1996 B7100 Kubota did not come from the factory with power steering. :D
If there is power steering it is an aftermarket add on.:)
   / Kubota 7100 HST power steering problem #3
Yep, Larry, like Egon said. I bought a new one in 1995 myself. They didn't have power steering and I've never even seen an aftermarket power steering on a B7100. I've seen some aftermarket, add-on power steering arrangements on some bigger older tractors of another brand, but never for the B7100.
   / Kubota 7100 HST power steering problem #5
OK, a B2100 is a bit different from a B7100, and I don't know about that.
I have a 96 Kubota B2100 HST 4 wheel drive and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is a plunger that is stuck? How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #8
Big difference between the 7100 and the B21.
If you increase the REV's does the steering get better?
b21's are a nice machine.:thumbsup:
no it does not turn easier if reved up,it has a loader and the hydraulics on it work fine
   / Kubota 7100 HST power steering problem #10
Would it be possible to get the pump output pressure and compare it to specs?:D
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
UNUSED DB500 DUSTLESS BLASTER (A51248)
UNUSED DB500...
Athey 7-12 Force Feed Loader (A52384)
Athey 7-12 Force...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2023 JOHN DEERE 2032R LOT NUMBER 100 (A53084)
2023 JOHN DEERE...
