Kubota 7100 HST power steering problem
   / Kubota 7100 HST power steering problem #1
Larry923
Grand Rapids,Mn
Kubota 7100 HST
I have a 96 Kubota 7100HST and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is plunger that is stuck? I was told it is a 1996 model on the hood it says power steering it is a B2100 HST 4 wheel drive How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #2
A 1996 B7100 Kubota did not come from the factory with power steering. :D
If there is power steering it is an aftermarket add on.:)
   / Kubota 7100 HST power steering problem #3
Yep, Larry, like Egon said. I bought a new one in 1995 myself. They didn't have power steering and I've never even seen an aftermarket power steering on a B7100. I've seen some aftermarket, add-on power steering arrangements on some bigger older tractors of another brand, but never for the B7100.
   / Kubota 7100 HST power steering problem #5
OK, a B2100 is a bit different from a B7100, and I don't know about that.
I have a 96 Kubota B2100 HST 4 wheel drive and it steers hard I don't think the power steering is working correctly (I just bought the tractor) any ideas? I have been told it is a plunger that is stuck? How can I check the #'s to see what year it is?thanks Larry
   / Kubota 7100 HST power steering problem #8
Big difference between the 7100 and the B21.
If you increase the REV's does the steering get better?
b21's are a nice machine.:thumbsup:
no it does not turn easier if reved up,it has a loader and the hydraulics on it work fine
   / Kubota 7100 HST power steering problem #10
Would it be possible to get the pump output pressure and compare it to specs?:D
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
UNUSED WOLVERINE GB-11-72W-72" HYD GRAPPLE BUCKET (A51248)
UNUSED WOLVERINE...
UNUSED FUTURE FT-B320 42" ROCK BUCKET (A51248)
UNUSED FUTURE...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
FRONTIER CA2072 LOT IDENTIFIER 41 (A53084)
FRONTIER CA2072...
