kubota 6315 quick attach on bx2200?
   / kubota 6315 quick attach on bx2200? #1
johann
bx2200
has any one tried the kubota 6315 quick attach on a first gen bx2200?
   / kubota 6315 quick attach on bx2200? #2
I did. it works. Cut off the back of the bucket to keep the pins aligned. Added 3 inch square tubing and then added the quick attach setup. I made my own previous setup and once I got the kit for my bigger tractor I switched immediately because its just that much better. So you have a plate with the 3 pins, and then the quick attach levers and angle pieces. I'll see if I have a picture around.
   / kubota 6315 quick attach on bx2200? #3
If they need to be bigger, let me know. I can't remember if these shrink down or not. Hope this helps
   / kubota 6315 quick attach on bx2200? #4
I believe johann is talking about the bx6315 which is different than what you're talking about.
Kubota BX6315 for sale in Pipersville, PA. Pipersville Garden Center Pipersville, PA (215) 766-414
   / kubota 6315 quick attach on bx2200? #5
whoops! I am sorry. But the setup is the same as mine with the single middle cylinder. I thought about going that route until you are stuck with kubota only attachments. I wanted to be able to get any attachment I wanted. Being stuck with kubota only attachments limited what I could buy. Just my opinion though. I thought it was an awesome setup they made, but owning 2 tractors would have been **** trying to adapt one to the other type thing.
   / kubota 6315 quick attach on bx2200? #6
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
Duetz Power Unit (A50120)
Duetz Power Unit...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
