kubota 6315 quick attach on bx2200?
   / kubota 6315 quick attach on bx2200? #1
johann
bx2200
has any one tried the kubota 6315 quick attach on a first gen bx2200?
   / kubota 6315 quick attach on bx2200? #2
I did. it works. Cut off the back of the bucket to keep the pins aligned. Added 3 inch square tubing and then added the quick attach setup. I made my own previous setup and once I got the kit for my bigger tractor I switched immediately because its just that much better. So you have a plate with the 3 pins, and then the quick attach levers and angle pieces. I'll see if I have a picture around.
   / kubota 6315 quick attach on bx2200? #3
If they need to be bigger, let me know. I can't remember if these shrink down or not. Hope this helps
   / kubota 6315 quick attach on bx2200? #4
I believe johann is talking about the bx6315 which is different than what you're talking about.
Kubota BX6315 for sale in Pipersville, PA. Pipersville Garden Center Pipersville, PA (215) 766-414
   / kubota 6315 quick attach on bx2200? #5
whoops! I am sorry. But the setup is the same as mine with the single middle cylinder. I thought about going that route until you are stuck with kubota only attachments. I wanted to be able to get any attachment I wanted. Being stuck with kubota only attachments limited what I could buy. Just my opinion though. I thought it was an awesome setup they made, but owning 2 tractors would have been **** trying to adapt one to the other type thing.
   / kubota 6315 quick attach on bx2200? #6
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2008 FORD F-350 (A52472)
2008 FORD F-350...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
