Oil & Fuel kubota 4900 hydraulic fluid problems
/ kubota 4900 hydraulic fluid problems #1
mrelder
massey 1030
kubota 4900 has hydraulic problems. Must warm up for a while before lift works.
Hydraulic fluid dip stick shows a LOT of water.
When I pull the dipstick; milky fluid flows out of it.
Any suggestions where the water is getting in?
I am gonna change the fluid and filter, but I would like to find where the water is getting in there.
Thanks in advance.
mike
/ kubota 4900 hydraulic fluid problems #2
Gear shift boot..........:2cents:
good answer peter 315!
the gear shift boot is defective!
large hole on top of rubber boot
thanks to you
/ kubota 4900 hydraulic fluid problems #5
Your going to change the hyd oil a couple of times (maybe more) to get all the water out......
thank you peter
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61306)
2006 Heil Tanker...
2018 FORD TRANSIT 350 CARGO VAN (A59905)
2018 FORD TRANSIT...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
1999 John Deere 7810 (A60462)
1999 John Deere...
