Oil & Fuel kubota 4900 hydraulic fluid problems
   / kubota 4900 hydraulic fluid problems #1
mrelder
massey 1030
kubota 4900 has hydraulic problems. Must warm up for a while before lift works.
Hydraulic fluid dip stick shows a LOT of water.
When I pull the dipstick; milky fluid flows out of it.
Any suggestions where the water is getting in?
I am gonna change the fluid and filter, but I would like to find where the water is getting in there.
Thanks in advance.
mike
   / kubota 4900 hydraulic fluid problems #2
Gear shift boot..........:2cents:
good answer peter 315!
the gear shift boot is defective!
large hole on top of rubber boot
thanks to you
   / kubota 4900 hydraulic fluid problems #5
Your going to change the hyd oil a couple of times (maybe more) to get all the water out......
thank you peter
200 Gallon Tank (A57149)
200 Gallon Tank...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
Case IH Maxxum 115 (A57148)
Case IH Maxxum 115...
JCB 3CX 14HFCA BACKHOE (A52709)
JCB 3CX 14HFCA...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
1998 Freightliner FL70 S/A Dump Truck (A59213)
1998 Freightliner...
